Error: Update failed for the setup component in Fluid Flow CFX
Like Tree1Likes
  • 1 Post By nudi1001
Old   February 24, 2018, 04:04
Default Error: Update failed for the setup component in Fluid Flow CFX
nudi1001 is on a distinguished road
Hello everyone,
i'm working on the analysis of a fan and i have succesfully set up and solved and Fluid Flow component system (CFX).
After changing the mesh (generating of the new mesh was successful), the update for the CFX setup failed with the following message:
__________________________________
'Update failed for the setup component in Fluid Flow (CFX). Application error in CFX-Pre: ERROR gtmAction: unknown operation, 'merge assembly' specified
System.ApplicationException: Application Error in CFX-Pre: ERROR
gtmAction: unknown operation, 'mergeAssembly', specified
at Ansys.CFX.Foundation.App.CUEApplicationProxy.SendC md(String code, String data, Int32 maxWait, Boolean ignoreCUEErrorDuringSendCmd)
at Ansys.CFX.Foundation.App.CUEApplicationProxy.SendC CL(String ccl, Boolean ignoreCUEErrorDuringSendCmd)
at Ansys.CFX.CFXCore.App.CFXPreProxy.UpdateMesh(IFull Context context, Int32 id, String fileName, ImportableMeshType fileType)
at Ansys.CFX.CFXCore.Data.CFXSetupSource.UpdatePreMes hes(IFullContext context)
at Ansys.CFX.CFXCore.Data.CFXSetupSource.LoadEditorDa ta(IFullContext context, Boolean interactive, Boolean dedicated)
at Ansys.CFX.Foundation.Data.CUESourceDataObject.Edit (IFullContext context, Boolean interactive)
at Ansys.Core.Commands.Concurrency.CommandWorkUnit.ex ecuteInContext(CommandContext subContext, IExecutionEngineCallback tracer)
at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExe cute(IExecutionEngineCallback executionEngine, CommandContext subContext)
at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execu te(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
--- Ansys.Core.Commands.CommandFailedException: Application Error in CFX-Pre: ERROR
CommandName: CFX.EditSetup(Container="Setup")
at Ansys.Core.Commands.CommandAsyncResult.RethrowFail ureException(Exception e)
at Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
at Ansys.CFX.CFXCore.Commands.EditSetupCommand.Invoke AndWait(IProtectedContext context, DataContainerReference Container, Boolean Interactive)
at Ansys.CFX.CFXCore.Commands.EditSetupGui.Invoke(Gui OperationContext context)
at Ansys.UI.GuiOperationContext.Invoke(GuiOperationMe taData operationData)
at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction)
I'm working with Ansys 17.1 on windows 7 and win 10, different OS same problem. Does anyone have an idea to solve this problem?
I Don't want to set up a complete new component system.
Thank you in advance!
nudi1001 is offline   Reply With Quote
Old   February 24, 2018, 09:33
Guille1811 is on a distinguished road
I also had a similar problem a couple of days ago, though not the same message. To solve it fixed a little problem in the geometry and redefined a couple of sizings and it updated well.
Also, an alternative solution that also worked is to export the mesh to a FLUENT format file (.msh i think) and then create a new proyect and import that mesh directly and then cfxpre should work fine.
Guille1811 is offline   Reply With Quote
Old   February 26, 2018, 05:44
thank you for possible solutions. I tested both of them with the same result.
I still don't know, why the initial mesh is working and after changing/adding/deleting some mesh properties it stucks...
And i also can't find any comparable problems in the forum.
Old   February 26, 2018, 08:10
I have found a solution. After opening the "corrupted" Setup, i have exported the CCL via File --> Export --> CCL. Next step is closing the CFX-Pre. In workbench "Clear generated data" on the setup of the Fluid flow. Openening the setup again with an initial state. In my case i have to generate some additional mesh regions in the CFX-Pre. Renaming these mesh locations according to the corrupt mesh before. Loading the CCL state and finally solve some problems occuring by bad links (in my case some wrong connections in the interfaces).
Thank you for your help!
-Maxim- likes this.
Old   January 17, 2023, 04:01
faraz naseri
faraz naseri is on a distinguished road
hello
i found best way for who can not access to the cfd post and result after their soloution that completed. in fluent you should export case, data and for who works in combustion field export pdf file too. then close the workbench. open another worbench, open fluent, import case and data , intiliaze them, after that in run section imput 1 iteration, after that close the fluent and open cfd post. done
faraz naseri is offline   Reply With Quote
cfx, failed, pre, update
Error message: Insufficient Catalogue Size Paresh Jain CFX 33 August 16, 2024 06:09
ERROR: Update failed for the Setup component in Fluid Flow (CFX). amsys Main CFD Forum 0 June 13, 2016 11:53
How to have multiple simulations in one Fluid Flow (CFX) study? amrbekhit CFX 0 February 20, 2011 06:13
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
CFX 4 for two continuous fluid flow solution sinjae CFX 1 May 19, 2001 04:07
