How to monitor an expression on a user surface on cfx pre? |
February 20, 2018, 10:33 |
Rep Power: 9 |
I need to monitor the average temperature on a user surface. I correctly imported the surface from another cfxpost export file, but when i try to create the monitor it doesnt recognize the surface. Specifically what i did was create an expression called "average temp" as ave(Temperature)@my user surface name, and then create a monitor for that expression. When i create the monitor it gives me the error of the unrecognized name.
I tried with all the different possible name for the surface (the one it originally had in the export file, the one it had on cfx post, etc) and nothing works. I also tried using the probe function as an alternative, but didnīt work either. How can i make this work? |
February 20, 2018, 10:53 |
M
Rep Power: 12 |
Use the search tool of this forum.
CFX: Insert custom mesh locators / Use user locations as locators in the expressions Referencing a User Location for a Monitor point expression in CFX pre It is not possible to create monitor points at custom locations like User Surfaces. As suggested in the first linked thread, a possible workaround would be to position any interfaces you have at the position you need to monitor. However, that would only work for a few cases, depending on where you try to monitor. |
February 20, 2018, 10:57 |
Rep Power: 9 |
Yes i used the search function and find that exact thread, but that solution doesnt fit me. Is there really no workaround way to do this? My surface is very specific and doesnt involve any interfaces nor interaction between bodies.
February 20, 2018, 11:02 |
Gert-Jan
Rep Power: 28 |
Apparently you did not understand what I wrote in the previous threads several times.
In monitoring you can only use mesh locators, meaning things that have been meshed. A user surface is not meshed, so it will not be accepted by Pre. Therefore you need to create an internal surface inside your geometry and mesh it. In Pre you don't have to set any physics on this internal surface. It just has to be present as mesh locator, so you can refer to it as monitoring object. |
March 1, 2018, 10:31 |
#5 | |
Rep Power: 18 |
March 2, 2018, 03:12 |
M
Rep Power: 12 |
Ok, this changes things. Thanks alot for that hint! I thought it was impossible.
Unfortunately, it does not seem to accept expressions to evaluate and monitor. Too bad since I need that. Anway, should be useful to alot of other people. |
March 2, 2018, 03:58 |
Rep Power: 18 |
You may try to create additional variable, activate it in domain settings and set it to be equal your expression, then select it for monitoring.
March 2, 2018, 04:02 |
M
Rep Power: 12 |
Good point. You seem to have used it before, so I have a few more questions:
1) are the monitors shown like all the others in solver manager? 2) are they included in trn output files? I could try it out I know, but its quite some effort for my case as I need to monitor >200 surfaces and it takes a while to set up. |
March 2, 2018, 04:12 |
#9 | |
Rep Power: 18 |
Using Residuals in CFX Pre to creat an Expression ? | Timmsen | CFX | 4 | August 20, 2014 08:21 |
Writing expression in CFX Pre using Cell Volume | debabrata.mahapatra | CFX | 1 | July 21, 2014 08:51 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
CFD Short Course & CFX User Day | Chris Reeves | CFX | 0 | September 11, 2000 08:53 |
