General grid interface
Like Tree2Likes
  • 2 Post By cdegroot
Old   August 25, 2003, 06:05
Default General grid interface
Daniele
Hi, I have a structured mesh an a unstructured mesh, between this meshes I have a GGI Connection. I'd like to know if there is a rapport between the nodes of the meshes that must be applay.
Tanks and have a nice day.
Daniele
Old   August 25, 2003, 17:47
Default Re: General grid interface
Robin
Daniele,
I'm not sure what you mean by "a rapport between the nodes", but if you are asking if you need to consider the topology on either side, the answer is no. The only consideration is that the geometric surfaces must be the same (within ~10% of element size). If you are dealing with a frame or pitch change, only the hub and shroud curves need to line up, the periodic surfaces don't.
Regards, Robin
Old   August 26, 2003, 02:56
Daniele
Hi Robin, thanks for your answer, was helpfull.
Regards, Daniele
Old   November 6, 2012, 12:01
su yunde
junc is on a distinguished road
Hi, Robin
i can't understand "hub and shroud curves need to line up", could you explain it?
thanks
junc is offline   Reply With Quote
Old   November 6, 2012, 13:48
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
I'm pretty sure people who submitted as Guests in 2003 are not going to respond...
k.vafiadis and junc like this.
cdegroot is offline   Reply With Quote
Old   November 6, 2012, 19:49
Wink
Kyriakos Vafiadis
k.vafiadis is on a distinguished road
Send a message via Skype™ to k.vafiadis
Originally Posted by junc View Post
Hi, Robin
thanks
Obviously they talk about turbomachinery where hub and shroud curves of each stage have to line up with each other .
Frame or pitch change may occur but the modeller's guide explains everything about the domain interfaces.
Kyriakos Vafiadis
Mechanical Engineer, PhD candidate
k.vafiadis is offline   Reply With Quote
Old   November 22, 2012, 03:15
su yunde
thank you for your reply, i get it.
interface information from fem grid ztdep Main CFD Forum 0 January 14, 2011 22:13
GGI (General Grid Interface) Connections feixiangniao CFX 4 January 14, 2010 20:51
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
moving mesh grid interface Dieter FLUENT 6 March 23, 2006 07:54
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
