January 16, 2018, 02:31 |
How to Pair both sides of the Membrane?
Mohsen Bahoosh
I am simulating a membrane. For calculation the local water mass flux I need to have the local amount of NaCl.mf on both sides of a 2D face (interface), that I defined it as a membrane. J water local=k(DeltaP-(NaCl.mf local on memside1*800-NaCl.mf local on memside2*800)) I will be appreciated if someone answers my questions: 1- What should I do about this? (CEL, FORTRAN or something else) 2- How can I write an expression that can calculate and relate the local mass fraction of NaCl on a particular face? (NaCl.mf@UPmembraneface) |
January 16, 2018, 08:57 |
Rep Power: 33 |
How do you define the membrane ? as a Fluid Fluid domain interface that behaves as a wall, i.e. thin surface ?
If you are using a thin surface, is there an option for mass transfer through the thin surface? I am sure there is an option for transfer of an additional variable where the flux across the surface is proportional to the difference of the variable on both sides. Hope the above helps, |
January 19, 2018, 12:20 |
#3 | |
Mohsen Bahoosh
July 24, 2019, 07:09 |
Dimitrios S. P.
Rep Power: 8 |
I also try to overcome this problem.
cfx, local permeability, mass fraction, membrane separation |
Simulation of a membrane distillation process (phase change and diffusion process) | fkika | OpenFOAM Pre-Processing | 1 | February 21, 2018 07:38 |
Seeking help in designing three types of deformable membrane boundary. | beancurd70 | OpenFOAM Programming & Development | 2 | October 1, 2013 16:23 |
porous filtration membrane area in model | catherina | CFX | 3 | October 27, 2011 06:05 |
gas diffusion through membrane | sosat1012 | CFX | 0 | September 8, 2010 08:14 |
mass transfer from fluids to membrane | Peter | FLUENT | 0 | August 2, 2002 14:27 |
