Anisotropic Thermal Conductivity in CFX 16.0
Like Tree1Likes
  • 1 Post By ghorrocks
Old   December 26, 2017, 11:48
Default Anisotropic Thermal Conductivity in CFX 16.0
Zahir Ummer Zaid
ZahirUZ is on a distinguished road
Hey all,
I am trying to simulate a battery cooling systems in CFX 16.0 and it is required to input the thermal conductivity of the cell as an anisotropic property.
Can someone direct me on how to implement anisotropic thermal conductivity. The thermal conductivity of the Li-ion cell is to be assigned as 0.32 W/m.K in the radial direction and 30 W/m.K in the axial direction, so I would have to employ a polar co-ordinates input.
I already tried tweaking the CCL of the material as given in the link http://www.eureka.im/2990.html . But when I import the edited CCL back to CFX, I get the following error message:
The parameter "Option" in "/LIBRARY/MATERIAL:Steel/PROPERTIES/THERMAL CONDUCTIVITY" has the value "Orthotropic Cylindrical Components". This does not match any of the allowed values: "Value, Kinetic Theory Model".
Is there any possible way to implement this successfully?
ZahirUZ is offline   Reply With Quote
Old   December 26, 2017, 17:31
This has been discussed many times on the forum. Do a search of the CFX forum for anisotropic thermal conductivity.
ZahirUZ likes this.
Old   December 26, 2017, 23:45
Zahir Ummer Zaid
Sir, I have tried the suggestions from the previous discussion. Many have suggested suppressing the cited error message. Can you comment on the credibility?
And also now I seem to have an issue trying to assign the new anisotropic material into the solid domain. I get the following error message:
The parameter "Material" in "/FLOW:Flow Analysis 1/DOMAIN: Default Domain/SOLID DEFINITION:Solid 1" has the value "AnisoMaterial". This does not match any of the allowed values: "Aluminium, Copper, Steel".
And I can't find anisotropic material in the material selection box. Kindly clarify.
Old   March 27, 2019, 04:03
urosgrivc
urosgrivc is on a distinguished road
I have exactly the same problem, (Ansys 19.0)
Has anybody managed to solve it?
How to make this work?
THERMAL CONDUCTIVITY :
Option = Orthotropic Cartesian Components
Thermal Conductivity X Component = `. [W m^-1 K^-1]
Thermal Conductivity Y Component = ` [W m^-1 K^-1]
Thermal Conductivity Z Component = `. [W m^-1 K^-1]
END
When I change it in ccl of the material than the cfx doesent want to accept this material anymore
If you suppress the error messages
Everything seems to work ok accordingly to OUTfile
in The OUTfile the chosen material and its orthotropic properties are ok,
it bothers me that cfxpre still shows the wrong material as it was changed due to error
urosgrivc is offline   Reply With Quote
Old   March 27, 2019, 05:54
Opaque will become famous soon enough
It is a beta feature, and it is not supported in the UI.
Opaque is offline   Reply With Quote
Anisotropic thermal conductivity UDF Kwiaci Fluent UDF and Scheme Programming 2 January 20, 2017 09:42
Question about anisotropic thermal conductivity Szweyk STAR-CCM+ 2 June 30, 2016 09:26
anisotropic thermal conductivity sieginc. STAR-CCM+ 1 December 15, 2012 17:08
anisotropic thermal conductivity Lugdi Siemens 0 January 15, 2007 09:03
Porous Media Effective Thermal Conductivity Greg Perkins FLUENT 3 August 5, 2001 22:53
