Referring to parameters of multiple results in CFD-POST scripts
Like Tree1Likes
  • 1 Post By ghorrocks
Old   December 18, 2017, 16:21
Question Referring to parameters of multiple results in CFD-POST scripts
Shafa HN
shafa_hn is on a distinguished road
Dear All
I need to import several results (*.res) on the same geometry and mesh, in one session of CFD-post and do calculation using parameters from both cases. How could it be referred to parameters of both cases in CEL/CCL scripts in one equation?
Thanks for your comments.
shafa_hn is offline   Reply With Quote
Old   December 18, 2017, 17:43
I have deleted the duplicate post of this thread.
What parameters are you trying to use? What are you trying to do with them?
Automation of CFD-Post is normally done through session files.
Old   December 22, 2017, 14:04
Default to find secondary flow field
Shafa HN
I need to write an equation based on parameters of both cases from different solution (geometry and mesh would be the same).
For example, I want to subtract the Velocity Fields of each cases, in order to have a new Velocity field for further manipulations and calculations. Actually I need it to calculate secondary flows in turbomachinery flow passage (by subtracting inviscid field from viscous field).
Old   December 22, 2017, 18:07
CFD-Post can do this. Load multiple results files and select the comparison option (I think it is the comparison option, I am away from my workstation so cannot check). This will give the difference of two results.
You can also load multiple results files and refer to them separately in expressions, so you can do more complex operations than just the difference.
shafa_hn likes this.
Old   December 23, 2017, 10:52
Post CEL sample
Shafa HN
Many thanks Ghorrocks for your helpful note. CFD-post-compare just provide an interface for showing difference but as you correctly mentioned, I need to do more complex calculation on both.
But, I don't know how to refer to the different variables in the CEL code. For example, for the following line:
! $Density0 = massFlowAve("Density","INFLOW");
how could I specify the "Density" and "INFLOW" belongs to which case?
cfd-post, multiple result
hello please after the simualation how i can save the results in post cfd luca007 FLUENT 1 February 14, 2017 07:01
Collect transient results CFD POST mortain CFX 15 April 17, 2015 09:29
CFD Post. Multiple results comparison zombiaska Visualization & Post-Processing 1 December 23, 2014 17:06
static enthalpy calculation in CFD Post newbie384 CFX 2 March 22, 2014 08:28
CEL mathematical functions in CFD Post Jonathan CFX 9 November 5, 2012 09:37
