December 1, 2017, 14:44 |
Viscous work at tip
Rep Power: 10 |
I am modeling an open impeller centrifugal pump with a fairly small tip clearance in CFX. I noticed that in the expert parameters, there is an option named "viscous work at tip". I could not find any documentation about this expert parameter. So my question is: 1- Does anybody know if activating this option will affect my solution considering that this is an incompressible flow simulation? 2- Can anyone point me to a publication or piece of documentation about the theory behind this term? (I assume this is different than the viscous terms in the energy equation) Thank you |
December 1, 2017, 19:52 |
Rep Power: 144 |
The first rule of expert parameters is you don't use them unless you know what they do
You have misread it. The parameter is "Viscous work at ip", with the documentation describing it as "Discretizes the viscous work term in the energy equation at integration points (ip)." It has nothing to do with rotor tip clearance vorticies. |
December 5, 2017, 20:30 |
Rep Power: 10 |
Thanks Glenn. Sorry about the misread
centrifugal pump, tip-clearance, viscous work |
Viscous resistance coefficients in porous medium | fpingqian | FLUENT | 50 | June 26, 2019 02:55 |
[TurboGrid] Meshing a non flat tip blade | Luza Belmont | ANSYS Meshing & Geometry | 3 | November 25, 2017 09:59 |
[ICEM] Unstructure Meshing at the Wing Tip Surface from Imported Plot3D Structured Mesh | yona | ANSYS Meshing & Geometry | 8 | January 21, 2014 11:06 |
Linearization of viscous flux in discontinuous Galerkin finite element methods | yidongxia | Main CFD Forum | 1 | November 17, 2011 13:11 |
Include Viscous Work term (in fluid model) | mehshan.javaid | Main CFD Forum | 0 | September 22, 2011 11:43 |
