November 15, 2017, 05:08 |
CFD-Post Case comparison
Jan Surwiło
Rep Power: 9 |
Hi All,
I have loaded two cases into CFD-Post. Case1 adiabatic and Case2 diabatic. I want to create new variable for HTC = q/(Tadiabatic - Twall). How to write expression for where q is taken from Case2 diabatic and Tadiabatic from Case 1 adiabatic? |
November 15, 2017, 06:17 |
Lance
Rep Power: 22 |
You need to make a reference to the case in the expression.
Example: areaAve(Velocity u)@CASE:1.Inlet |
November 15, 2017, 06:36 |
Jan Surwiło
Rep Power: 9 |
Thanks Lance,
But this is not what I'm looking for. The example you gave will show average value. What I want, is to get expression for variable to get local value of HTC. I tried expression like: (Wall Heat Flux)@Case2/((Temperature)@Case1 - Twall). But it doesn't work. I can import adiabatic results to diabatic as an external data but I want to evaluate HTC in one expression. |
November 15, 2017, 06:45 |
Lance
Rep Power: 22 |
Sorry, didnt read carefully. Im not sure you can do it - @Case only works for functions such as area(), ave(), and so on.
But why do you need do to it, if you can solve it by importing external data? |
November 15, 2017, 07:03 |
#5 | ||
Jan Surwiło
Rep Power: 9 |
I will be looking for different solution Thanks anyway |
December 19, 2018, 04:46 |
#6 | |
serg
Rep Power: 11 |
Were you able to do it? If so, can you explain in short? I believe it is possible in tecplot, but couldnt do it in CFD post. Thanks. |
December 11, 2019, 08:52 |
Lorenzo Mazzei
Rep Power: 16 |
You have to make a Frozen Copy of Temperature from the first case and then import the second one.
cfd-post, expression editor, htc |
Post processing in CFD Post or Fluent. | Blobs | OpenFOAM Post-Processing | 2 | June 26, 2016 08:23 |
Problem regarding producing streamlines from surfaces in Ansys CFD post | gauthamnarayan | Visualization & Post-Processing | 0 | April 23, 2015 17:07 |
CFD Post Case Comparison | akarlin | CFX | 0 | March 3, 2013 21:52 |
CFD Post crashed | davidwilcox | FLUENT | 1 | February 23, 2013 01:41 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 13, 1999 00:27 |
