How to calculate total area of a range of pressure |
November 5, 2017, 03:53 |
Jimmy
Rep Power: 10 |
I can calculate pressure on any surface, but I would like to calculate total area of any range of pressure by CFX. For example, I have the pressure pattern or pressure contour, I want to know the total area of pressure from 1Pa to 2Pa. How can I do that? CFX post can get this result, right?
November 5, 2017, 05:01 |
Rep Power: 144 |
In CFD-Post, define a contour object with the contour lines you want. Then define a user surface using the contour lines as the method.
November 5, 2017, 20:08 |
Jimmy
Rep Power: 10 |
Thank you so much for your reply, check my steps plz, if I understand your suggestion clearly.
step1, define a new contour and value range use `user specified` step2, define a `user surface` and method select from the contour which is defined in step1 step3, use calculators`s function calculator and select area function and location `user surface` which is defined in step2 an question. `#of contours` and `contour level` value is not important in this calculation,right? Thank you for your kindness! |
November 5, 2017, 20:10 |
Jimmy
Rep Power: 10 |
I need your help really.
November 6, 2017, 02:13 |
Rep Power: 144 |
That sounds about right. Why don't you just try it and see if it works?
November 6, 2017, 19:25 |
Jimmy
Rep Power: 10 |
Total Pressure or Total Pressure in Rel Frame | MissCFD | CFX | 4 | March 24, 2015 05:19 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 02:27 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
rotating frame of reference and total pressure | viking | ANSYS | 1 | November 24, 2010 00:25 |
Total pressure in a laval nozzle | Sohail Ahmed | FLUENT | 0 | May 19, 2004 06:28 |
