Flow Separation in GE frame 9 Compressor CFD simulation |
i man
Rep Power: 13 ![]() |
Has anybody simulated GE frame 9 Compressor? I had simulated this 17th stages compressor with the CFX; when I used a coarse mesh with y+=30 and k-w turbulence model, there is no problem in convergence and everything in CFD-POST is fine. But when it comes to simulating with a fine mesh, y+=1 and SST turbulence model; Inlet mass decreases and post-process show a big region of flow separation near the leading edge close to the hub. Can anybody give me any tips?
Typically, certain flow effects are not captured on coarse mesh. They are smeared over the cell volume. Separation at the hub is a problem. Try to eliminate/isolate the problem and simulate the stage with different boundary conditions (reduce discharge pressure, or mass for example). See if the separation is still present.
Frankly, I do not have experience with that particular frame. CFDpal |
compressor, flow seperation |
Which turbulence model is applicable for Plain diffuser flow simulation in openFOAM? | mukut | OpenFOAM Running, Solving & CFD | 4 | January 30, 2015 08:06 |
how to get a time-accurate solution in Flow Simulation | drdet | FloEFD, FloWorks & FloTHERM | 4 | January 20, 2015 07:11 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
[CFX] Simulation of Flow Separation in a rectangular diffuser - Convergence Problem | anon_b | CFX | 11 | May 6, 2012 20:16 |
Differences and functions of Solidworks Simulation and Solidworks Flow Simulation? | alpharays | Main CFD Forum | 0 | April 19, 2012 03:13 |
