cfx solvers -FVM?
Like Tree3Likes
  • 2 Post By Sharks
  • 1 Post By Robin
Old   February 5, 2003, 13:54
Default cfx solvers -FVM?
derrek
Is cfx all FVM based?
Old   February 5, 2003, 17:53
Default Re: cfx solvers -FVM?
Robin
Yes. CFX uses an element based Finite Volume Method.
-Robin
Old   February 6, 2003, 07:58
derrek
The PI sheet for cfx5 states the following "Conservative finite-element based control volume method"
This implies FVM?
Old   February 7, 2003, 19:19
Sharks
Hi Derrek
CFX-5 uses an unstructured Finite Element based Finite Volume method. The FE basis comes from the use of shape functions, common in FE techniques, to describe the way a variable changes across each element. It is also a node based code, where the solution variables are solved and stored at the centers of the finite volumes, or the vertices of the mesh.
I believe TASCflow employs a similar strategy, except that it can solve on only block-structured hexagonal meshes.
CFX-4 uses a cell-centered Finite Volume/Finite Difference method.
Sharks
Mostafa.F.H and aero_head like this.
Old   February 9, 2003, 08:50
derrek
sharks, thanks for the info.
I am not that familiar with the FVM. Still not sure where the finite volume comes into play in regards to cfx4. If it is an unstructured mesh using shape functions, how does it differ from a true FE based solver?
cheers, derrek
Old   February 10, 2003, 12:50
Robin
Hi Derrek,
A control volume is analagous to the finite volume.
Six of one, half a dozen of another.
Regards, Robin
aero_head likes this.
CFX vs. Fluent George FLUENT 43 May 16, 2012 00:42
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
Electronics Enclosure Analysis with CFX Simulation Engineer CFX 1 April 22, 2009 12:08
CFX 10 in CFX 5.7 panneerselvam.R CFX 6 February 6, 2006 04:56
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
