boundary conditions of centrifugal compressor |
October 10, 2017, 17:42 |
I am doing flow simulation of centrifugal compressor
since my inlet and exit are very short, so i gave opening as boundary condition for inlet and outlet but i was unable to understand what values should i define, and what options should i choose for opening boundary condition so please could someone help me, |
October 10, 2017, 18:43 |
Rep Power: 144 |
You can only put boundary conditions at locations where you know the flow conditions. You then impose those flow conditions as a boundary condition on your domain. If you do not know the flow condition at a location then you cannot put a boundary condition there.
If you can explain what you do know about this device then we can try to help you select the correct boundary conditions. |
October 11, 2017, 02:45 |
Thank you for your reply
I modelled centrifugal compressor in solidworks and i imported to cfx, now i want know how much pressure rise, this model can achieve at sea level conditions, so what are the values that i need to define, and what options should i choose, if i keep opening as boundary condition at inlet and outlet (like do i need to choose "static pressure and dir" or "opening pressure and dir" say if i choose "opening pressure and dir", "opening temperature" then what value that i need to define for relative pressure , temperature etc ) |
October 11, 2017, 06:51 |
Rep Power: 144 |
If you read the CFX documentation on Tips for selecting boundary conditions it describes the options and their advantages and disadvantages.
centrifugal compressor, opening boundary |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 09:44 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 05:39 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
