August 1, 2002, 07:10 |
Turn off velocity Equations
Dear all,
I want to seek a suggestion to turn off the velocity equations, i.e. fixed U, V, W, for the Solver run. Anyone can help me? Thank you. Nelson |
August 1, 2002, 10:06 |
Re: Turn off velocity Equations
Which solver are you using?
In CFX-5 you can set fluids = f in the expert parameters. In TASCflow, in the PRM file: fluids = f; turbmd = f; tmptre = f will turn of the fluids, turbulence and energy equations respectively. In CFX-4, I don't know how to do it. Regards, cfd guy |
August 2, 2002, 03:48 |
Hi, excuse my ignorance please.I would like to know when & why it is suitable to turn off these eqs?
August 2, 2002, 05:08 |
I can be helpfull if you want to calculate different temperatures or (passive) scalars distributions at a given flow field. Provided they do not disturb your flow field, that's what you assume..
Astrid |
August 2, 2002, 05:11 |
In CFX 4 you can turn off UVW and p with the keyword:
ITERATIONS OF HYDRODYNAMIC EQUATIONS 0 in the subject: >>SOLVER DATA >>PROGRAM CONTROL Astrid |
August 2, 2002, 06:07 |
Thank you ,Astrid
August 2, 2002, 08:48 |
I use to turn off all equations (turbulence, fluids and energy) when I'm testing a new moving grid with the TASCFlow code.
August 2, 2002, 18:09 |
I very often use this approach when dealing with combustion or heat transfer problems. I have noticed in such problems that the velocity and pressure field might have converged or does not change anymore but the residuals for the temperature/enthalpy is still decreasing. It can take very long time, many iterations, for settling the solution for the temperaure, solving the velocity and pressure just increase the computational time. So I normally get a converged solution on the velocities and then do a restart without solving the velocities. I have found this to be very efficient.
September 20, 2002, 06:16 |
#9 |
When you put fluids = f in tascflow, the momentum as well as continuity equations are turned off. Is it possible to just turn of momentum or continuity equation selectively, or even better, u-, v-, or w- componets of momentum equations separately? I normally get mass converged very quickly but one particular momentum equations (W in my case as the main flow direction is Z) takes time to solve.
Thanks |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 09:08 |
Plotting Radial Velocity and Tangential Velocity in CFD Post | ashtonJ | CFX | 5 | July 13, 2015 02:49 |
Results of CFX Simulations | Sof_70_Usthb | CFX | 3 | July 9, 2011 06:15 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 06:10 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
