July 27, 2017, 05:24 |
How to plot stream function in CFD post?
Rep Power: 16 |
how I want plot contour for stream function in CFD-Post? I cannot find it?
Thanks a lot |
July 27, 2017, 07:37 |
Rep Power: 144 |
You have to define a variable which defines streamfunction, and do processing on that.
July 27, 2017, 08:24 |
Rep Power: 16 |
July 27, 2017, 08:32 |
Rep Power: 144 |
July 27, 2017, 08:51 |
#5 | |
Rep Power: 16 |
As i understood from this post I think the relation of stream function can be written in terms of axial velocity as below:
Stream function=axial velocity (u) * vertical distance (y) Is it right? Quote:
July 27, 2017, 08:56 |
Rep Power: 144 |
That does not sound right to me
Streamfunction is only defined for 2D flows. Is your flow 2D? |
July 27, 2017, 08:59 |
Rep Power: 16 |
July 27, 2017, 09:19 |
Rep Power: 144 |
The velocity field is the derivative of the velocity field, so to get stream function from the velocity field you will need to integrate the velocity over the flow domain. There is no built in function to do this, you will need to write a routine to do it. I don't think you can do this in CFD-Post either, you will need something with more mathematical power (matlab, python etc).
July 29, 2017, 03:30 |
#9 |
NISHANT
Rep Power: 10 |
Well Mariam, First of all you develop the simulation of the defined problem after that if the solution is converted successfully the go to the export solution in that there is an option of stream function you can export as ASCII or CGNS forma open the ASCII in MS Excel or CGNS in CFD-Post here you have all the value of stream function at all the nodes.
Is that helpful?? If not please provide the detail of whole problem. Thank You Sent from my Tab2A7-20F using CFD Online Forum mobile app |
July 30, 2017, 04:45 |
#10 | |
Rep Power: 16 |
Thank you NISHANT for the reply. My solution converged successfully but I cannot find steam function in export option in CFD-Post it not exist? may you send me illustrated photo if possible?
Thanks mariam Quote:
July 30, 2017, 04:57 |
#11 |
NISHANT
Rep Power: 10 |
Hi Mariam I am sorry but I have to do the simulation in Fluent provide a wonderful sets of parameters to be exported you can also send me the mesh flow I will do it foryou
July 30, 2017, 05:05 |
#12 | |
Rep Power: 16 |
You made me confused ? I am talking about CFX not FLUENT?
July 30, 2017, 05:11 |
#13 |
NISHANT
Rep Power: 10 |
Yes I know the difference but do CFD have any option to export the case and data file.
July 30, 2017, 05:15 |
#14 |
NISHANT
Rep Power: 10 |
Give me you email I will send you an image to how to do it in fluent?
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 20, 2015 00:40 |
CFD Post Streamlines better representation? | Dr. Flow Squad | CFX | 2 | January 20, 2014 14:48 |
Plot of user defined variable in CFD Post | dreamz | Main CFD Forum | 0 | December 8, 2013 23:00 |
streamline plot for multiphase problem | lionlove0903 | OpenFOAM Post-Processing | 2 | March 14, 2011 16:25 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 13, 1999 00:27 |
