A CFX-POST error (ver 14.5.7)
Like Tree1Likes
  • 1 Post By -Maxim-
Old   July 14, 2017, 11:16
Question A CFX-POST error (ver 14.5.7)
wangyflp88 is on a distinguished road
Hello, I'm new here.
I have a problem about the cse file in CFX-POST.
I found my cse file generated by my own programs didn't work in both batch mode and interface mode.
So I recorded a short cse file in the CFX-POST interface to see whether there is something wrong with my cse generating programs. And it ran successfully.
But the weird thing is, when I open that cse file(recorded by CFX-POST) with UltraEdit, copy all the codes to a new file and save it as an *.cse file, it doesn't work at all.
The error information is like this
ERROR
CCL parser failed with message:
parseCCLLineH: syntax error near ""
And the cse is like this
# Session file started: 2017/07/14 00:14:12
# CFX-14.5.7 build 2013.03.09-06.03
# To avoid unnecessary file pre-processing and modifications, include
# COMMAND FILE at the top of your session file.
# If it is not included, the file is assumed to be older and will be
# modified for backward compatibility.
COMMAND FILE:
CFX Post Version = 14.5
END
DATA READER:
Clear All Objects = false
Append Results = false
Edit Case Names = false
Open to Compare = false
Multi Configuration File Load Option = Last Case
Open in New View = true
Keep Camera Position = true
Load Particle Tracks = true
Files to Compare =
END
DATA READER:
Domains to Load=
END
> load filename=I:\SLICE_COOL_SS_Velo\SLICE_COOL_SS_0.0_V elo_140\\
SLICE_COOL_SS_0.0_Velo_140_Transient_001\4890_full .trn, force_reload=true
VIEW:View 1
Camera Mode = User Specified
CAMERA:
Option = Pivot Point and Quaternion
Pivot Point = 3.26446, 0.034601, 0.07
Scale = 10.0991
Pan = 0, 0
Rotation Quaternion = 0.279848, -0.364705, -0.115917, 0.880476
END
END
>readstate filename=I:\SLICE_COOL_SS_Velo\SLICE_COOL_SS_0.0_V elo_140\\
SLICE_COOL_SS_0.0_Velo_140_Transient_001\4890_laye rlines.cst, mode = append, \
load = false, keepexpressions = true
EXPORT:
ANSYS Export Data = Element Heat Flux
ANSYS File Format = ANSYS
ANSYS Reference Temperature = 0.0 [K]
ANSYS Specify Reference Temperature = Off
ANSYS Supplemental HTC = 0.0 [W m^-2 K^-1]
Additional Variable List =
BC Profile Type = Inlet Velocity
Export Connectivity = Off
Export Coord Frame = Global
Export File = I:/SLICE_COOL_SS_Velo/SLICE_COOL_SS_0.0_Velo_140/\
SLICE_COOL_SS_0.0_Velo_140_Transient_001/ECA_B01S25_SL_4890.csv
Export Geometry = On
Export Location Aliases =
Export Node Numbers = Off
Export Null Data = On
Export Type = Generic
Export Units System = Current
Export Variable Type = Current
External Export Data = None
Include File Information = Off
Include Header = On
Location = BLADE1
Location List = /POLYLINE:sl025 201
Null Token = null
Overwrite = On
Precision = 8
Separator = ", "
Spatial Variables = X,Y,Z
Variable List = EC1
Vector Brackets = ()
Vector Display = Scalar
END
>export
EXPORT:
SLICE_COOL_SS_0.0_Velo_140_Transient_001/ECA_B01S25_PL_4890.csv
Include Header = On
Location = BLADE1
Location List = /POLYLINEl025 201
Null Token = null
Overwrite = On
Precision = 8
Separator = ", "
Variable List = EC1
END
>export
EXPORT:
SLICE_COOL_SS_0.0_Velo_140_Transient_001/ECA_B01S50_SL_4890.csv
Include Header = On
Location = BLADE1
Location List = /POLYLINE:sl050 201
Null Token = null
Overwrite = On
Precision = 8
Separator = ", "
Variable List = EC1
END
>export
EXPORT:
SLICE_COOL_SS_0.0_Velo_140_Transient_001/ECA_B01S50_PL_4890.csv
Include Header = On
Location = BLADE1
Location List = /POLYLINEl050 201
Null Token = null
Overwrite = On
Precision = 8
Separator = ", "
Variable List = EC1
END
>export
EXPORT:
SLICE_COOL_SS_0.0_Velo_140_Transient_001/ECA_B01S75_SL_4890.csv
Include Header = On
Location = BLADE1
Location List = /POLYLINE:sl075 201
Null Token = null
Overwrite = On
Precision = 8
Separator = ", "
Variable List = EC1
END
>export
EXPORT:
SLICE_COOL_SS_0.0_Velo_140_Transient_001/ECA_B01S75_PL_4890.csv
Include Header = On
Location = BLADE1
Location List = /POLYLINEl075 201
Null Token = null
Overwrite = On
Precision = 8
Separator = ", "
Variable List = EC1
END
>export
> close
# Session file stopped: 2017/07/14 00:19:48
I really don't know why this happen, and where is "LineH".
I really need some help, thanks~
wangyflp88 is offline   Reply With Quote
Old   July 17, 2017, 04:34
Maxim
-Maxim- is on a distinguished road
My guess is that UltraEdit does some thing of auto-completion or manipulates the syntax in some way before you save it. Example: I use Notepad++ in Windows and when I type " the editor adds another " automatically. That could lead to mistakes. Of course I can deactivate that.
Either you find out what UltraEdit is doing with your files or you just try another editor.
wangyflp88 likes this.
-Maxim- is offline   Reply With Quote
Old   July 22, 2017, 01:17
Thank you for answering. I'll try other editors and debug my matlab program~
CFX Pre & Post Startup Error vigges CFX 12 March 17, 2023 04:30
Error reading profile data in expression in cfx post banu CFX 4 March 27, 2015 10:03
Turbine Blade Flutter additional Varialbles display error in CFX post sagarparikh31 CFX 8 January 27, 2015 08:22
Accessing cell values (CFX Pre and CFX Post) brahmarishiraj CFX 14 June 24, 2014 20:12
CFX post legend modification mactech001 CFX 3 December 25, 2011 23:12
