convergence rate with steady state simulations
Like Tree1Likes
  • 1 Post By ghorrocks
Old   July 4, 2017, 04:39
Default convergence rate with steady state simulations
cardioCFD is on a distinguished road
I know this might be discussed previously, and am sorry to bring this up again, but I could not solve my problem based on the previous posts.
I am solving a steady flow problem, say flow in a simple tube with "flux in" boundary conditions on the some portions of the walls for some of the "additional variables".
From physical point of view, the problem should reach steady state when the rate by which the additional variables are washed from the wall are equal to the rate by which the additional variables are released at the wall.
I have this "flux in" boundary conditions for three additional variables (i.e., AP, RP, and CF), while kinematic diffusivity of CF is 1000 times greater than AP and RP.
I get the solution converged for AP and RP after around 3500 iterations (automatic timescale) but the variable with higher diffusivity has a much slower convergence rate (far above the convergence criteria) even after 3500 iterations. Note, the velocity and pressure converged really fast at less than 100 iterations.
I am attaching a snapshot of the convergence curves, the convergence criteria is MAX RMS < 0.0005.
I was wondering if anyone can advise how I can get faster convergence.
Thanks a lot.
cardioCFD is offline   Reply With Quote
Old   July 4, 2017, 14:51
Opaque will become famous soon enough
You should read the documentation section titled: "Controlling the Timescale for Each Equation"
You should probably set the timestep for the specific additional variable to a larger value than it is currently using.
The CCL snippet you need is similar to
FLOW: Flow Analysis 1
  SOLVER CONTROL:
    EQUATION: CF
      CONVERGENCE CONTROL:
        Length Scale Option = Conservative
        Timescale Control = Auto Timescale
        Timescale Factor = 1000
      END
    END
  END
END
Please keep us posted on your progress with the above
Opaque is offline   Reply With Quote
Old   July 6, 2017, 05:37
  SOLVER CONTROL:
    EQUATION: CF
      END
    END
  END
END
Thanks a lot. I followed your advice and observed that an increase in CF timescale can remarkably increase the convergence rate of this equation. Thanks.
However, a new problem raised. As the additional variable AP, which already met the convergence criteria, is affected by CF (they are coupled), the increase in CF timescale affected AP and I saw a sudden increase in AP MAX RMS which turned into sustained oscillations far above the convergence criteria after some iterations.
Now the CF MAX RMS is monotonically decreasing (and is below convergence criteria) but AP MAX RMS is oscillating at a level above convergence criteria.
I would appreciate any advice on that.
Thanks a lot.
Best
Old   July 6, 2017, 07:28
There are many possible ways forward:
* Put a slower time scale on the AP equation
* Reduce the CF time scale
* Just continue on and converge CF and the others tighter and see what AP does - it might converge after a while.
cardioCFD likes this.
The difference between steady state and transient JuPa CFX 36 December 9, 2019 23:50
Solver for transonic flow? Martin Hegedus OpenFOAM Running, Solving & CFD 22 December 16, 2015 05:59
Convergence issues for steady turbulent diffusion flame stuntmanmike CFX 5 November 7, 2014 18:37
convergence problem in 3D steady state, laminar flow in a bath vajiheh FLUENT 0 July 10, 2009 13:18
Steady state verses Time accurate simulations Saud khashan Main CFD Forum 2 May 23, 2003 08:00
