Time stepping for multi-phase simulation
Like Tree1Likes
  • 1 Post By ghorrocks
Old   June 30, 2017, 11:17
Default Time stepping for multi-phase simulation
Praveen Gambhir
praveengambhir16 is on a distinguished road
Hello All!
I have recently simulated a multiphase water/air simulation. The scenario was water dripping from a hole into a container. I have considered a 5 degree wedge domain with symmetry faces which resulted in a considerable decrease in cell count. However, I have observed a very troubling issue with my run.
I have previously simulated the scenario of capillary rise phenomenon considering a 1e-5 time step. I've also tried adaptive timestep from another post in cfd-online, but the 1e-5 timestep worked very well, with a faster than considered computation time.
This current example, though, even with a 1e-5 timestep, took considerably longer to compute than expected (upwards of 15 hours with 128 cores distributed HPC, the number of mesh elements were less than 30,000). I've restricted the transient solution to 5 coefficient loops per timestep, with a convergence criteria RMS of 1e-4. What would be a more nominal transient time step value in order to reproduce the solution with reasonable accuracy, and reducing solve time?
Thanking You,
Praveen
TTI
praveengambhir16 is offline   Reply With Quote
Old   July 1, 2017, 08:02
The recommendation remains the same. Use adaptive time stepping homing in on 3-5 coeff loops per iteration. This is especially important if you are doing surface tension modelling. CFX requires VERY small time steps when you are doing surface tension modelling.
This results in very long run time with CFX. Try fluent, it has much better options for surface tension modelling and can run much faster than CFX.
Old   July 6, 2017, 09:24
Praveen Gambhir
Thank you very much, Mr.Horrocks. We are in the process of acquiring a Fluent license soon. I will use Fluent to solve the same case whenever we acquire a license. Are there any other tips, tricks or workarounds to get around the problem of unusually large computation time for surface tension problems?
Regards,
Praveen
TTI
Old   July 6, 2017, 19:36
With Fluent and surface tension - note the defaults are not the best for most simulations. You can make massive increases in speed and performance by optimising the settings. But the settings required for each simulation are different so you are going to have to try things out to find what works for you. But in particular look at NITA, and Geo-Reconstruct. But many other options are worth looking at as well.
BlnPhoenix likes this.
ansys 18.1, cfx, multiphase flow, transient
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
two Phase column simulation chemeng OpenFOAM 3 August 18, 2010 13:53
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 05:35
