June 17, 2017, 07:44 |
Source coefficients in CFX
Rep Power: 9 |
I am a bit confused about the use of source coefficients in CFX I am going to define a source (e.g., momentum) like this: Sx = K*u Sy = K*v Sz = K*w An estimate for the momentum source coefficient would be: C = dS/du = K. Now my question is this: which of the following CFX setups are correct: 1) Momentum source X = 1 [kg m^-3 s^-1] * u Momentum source Y = 1 [kg m^-3 s^-1] * v Momentum source Z = 1 [kg m^-3 s^-1] * w Momentum source coefficient = K / 1 [kg m^-3 s^-1] OR 2) Momentum source X = K * u Momentum source Y = K * v Momentum source Z = K * w Momentum source coefficient = K / 1 [kg m^-3 s^-1] I would appreciate any comment on this. Many thanks |
June 18, 2017, 07:45 |
Rep Power: 144 |
2 is correct. Your first comments on how to derive C is correct, so why do you think 1 could be valid?
And don't forget: the coefficient just assists convergence. If you get it wrong it probably won't converge. If you get it right it might converge. It should not affect the actual values of a converged solution. |
June 19, 2017, 07:07 |
Rep Power: 9 |
Thanks a lot Glenn.
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 09:06 |
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 18:25 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 02:22 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 06:18 |
