Polydispersed phase pressure drop with drop size
Like Tree2Likes
  • 1 Post By Laksh
  • 1 Post By ghorrocks
Old   June 8, 2017, 14:47
Default Polydispersed phase pressure drop with drop size
Lakshay Garg
Laksh is on a distinguished road
Hi all,
I am modeling a flow of air -water mixture through a filter media. The morphology of water in air is polydispersed. The question I want to post goes as follows:
" I model the pressure drop across the filter through a isotropic momentum loss model wherein I implemented the linear resistance coefficient(dependent on air velocity). Now, I am not sure if CFX takes into account the drop sizes or just the total volume fraction of the dispersed phase to calculate the pressure drop. In other words, if I reduce the size of droplets in the dispersed phase, for the same volume fraction, would CFX predict a higher pressure drop or would the pressure drop remain the same?"
I hope I explained my problem clearly!
Thanks in advance
Laksh
Svetlana likes this.
Laksh is offline   Reply With Quote
Old   June 8, 2017, 19:56
Can't you do a simple test simulation and find out? Send a air/water mixture through your porous media and change the drop size and see if makes a difference.
dispersed phase, pressure drop, size dependency
Pressure drop in pipe flow with Large Eddy Simulation xerox FLUENT 1 October 16, 2019 09:55
Excessive static pressure drop in elbow flow Teles CFD Freelancers 4 June 4, 2017 18:11
Computed Pressure Drop is lower than experimental data Ash Kot FLUENT 2 May 17, 2017 10:41
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
