June 3, 2017, 16:57 |
CFX vs Fluent convercenge residuals
Rep Power: 9 |
Hello all,
I'm doing some comparisons between CFX and Fluent in terms of speed and accuracy. I've done CFX runs where I set the target residuals at 1e-6 (as company methodology). When doing the Fluent runs I've came across that the recommended values were 1e-3... Anyone could explain me why this 3 order magnitude difference, as this has direct impact in the run duration? |
June 4, 2017, 01:55 |
#2 | |
Quang Le Dang
Rep Power: 14 |
Sent from my SM-A520F using CFD Online Forum mobile app |
June 4, 2017, 07:28 |
Rep Power: 144 |
I suspect CFX and Fluent calculate the residuals by different methods, so the numbers need to be compared with care.
To compare CFX vs Fluent objectively you need to compare a well resolved model in both cases. This means mesh independent, adequate convergence and any other tuneable parameters correctly set. It also means that the same settings are not necessarily the best for both - for instance the mesh which gives mesh independence could well be different in both software. Do not assume the same mesh is suitable for both codes. |
June 4, 2017, 09:14 |
#4 | |
Rep Power: 9 |
June 4, 2017, 09:23 |
Rep Power: 9 |
Yes I suspect the same, so I am asking if anyone can confirm this and have a guideline like "fluent residuals are 10x greater" or something like that.
June 4, 2017, 11:14 |
Quang Le Dang
Rep Power: 14 |
November 7, 2018, 16:25 |
#7 | |
Rep Power: 8 |
Please correct me if I'm wrong. |
November 7, 2018, 18:36 |
Rep Power: 144 |
I don't about know the residuals in Fluent, but for CFX the residuals are calculated by a propriety algorithm which has only a general outline described in the documentation. So it is not possible to compare the exact approach as it is not public.
convergence criteria |
[ANSYS Meshing] Solver preference - CFX vs FLUENT | gcoopermax | ANSYS Meshing & Geometry | 1 | May 31, 2017 20:17 |
Mesh and Solve Times for CFX, Fluent, CD-adapco | Jade M | Main CFD Forum | 4 | August 28, 2012 03:54 |
Fluent and CFX | Ale | Main CFD Forum | 7 | July 30, 2008 22:14 |
Jobs in cfd - fluent or cfx? | jobman | Main CFD Forum | 6 | July 5, 2006 16:02 |
CFX vs STAR-CD and Fluent | William | CFX | 20 | October 29, 2001 14:55 |
