Periodic Pressure drop
Like Tree1Likes
  • 1 Post By ghorrocks
Old   May 23, 2017, 04:57
Default Periodic Pressure drop
AKS
cfd_begin is on a distinguished road
Hello all,
I am simulating a periodic flow in a channel with square cross-section wherein I am modeling the effect of pressure drop using source term in the momentum equation as:
Sx = -C (areaavg (u)2inlet-Uref)
I am able to achieve convergence and solution. However, it shows pressure as:
Pinlet = Poutlet.
I wondering how can I calulate pressure drop?
Any suggestions, Please.
cfd_begin is offline   Reply With Quote
Old   May 23, 2017, 09:06
Please post an image of what you are modelling and your output file, editted to only show the CCL and a few convergence iterations please.
Old   May 24, 2017, 01:18
AKS
Dear Ghorrocks,
A shown in Figure, I am trying to simulate a fully developed flow using periodic boundary conditions. I am able to obtain the fully developed profile at a fixed mass flow rate.
Sx = -C (areaavg (u)@inlet-Uref)
Here Uref is obtained from the mass flow rate.
Pinlet = Poutlet.
I am also worried is this pressure the periodic part of the actual pressure ?
Some commands from output file:
LIBRARY:
CEL:
EXPRESSIONS:
C = 100000 [kg m^-3 s^-1]
Sx = -C*(areaAve(u)@REGION:INLET-0.001 [m s^-1])
END
END
MATERIAL: Water
ANALYSIS TYPE:
Option = Steady State
EXTERNAL SOLVER COUPLING:
Option = None
END
END
DOMAIN: Domain 1
Coord Frame = Coord 0
Domain Type = Fluid
Location = FLUID
BOUNDARY: Domain Interface 1 Side 1
Boundary Type = INTERFACE
Location = INLET
BOUNDARY CONDITIONS:
MASS AND MOMENTUM:
Option = Conservative Interface Flux
END
END
END
BOUNDARY: Domain Interface 1 Side 2
Location = OUTLET
MASS AND MOMENTUM:
END
END
END
BOUNDARY: wall
Boundary Type = WALL
Location = WALL
MASS AND MOMENTUM:
Option = No Slip Wall
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Option = Non Buoyant
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
Reference Pressure = 1 [atm]
END
END
FLUID DEFINITION: Fluid 1
Material = Water
Option = Material Library
MORPHOLOGY:
Option = Continuous Fluid
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Option = None
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = Laminar
END
END
SUBDOMAIN: Subdomain 1
Location = FLUID
SOURCES:
MOMENTUM SOURCE:
GENERAL MOMENTUM SOURCE:
Momentum Source Coefficient = -C
Momentum Source X Component = Sx
Momentum Source Y Component = 0 [kg m^-2 s^-2]
Momentum Source Z Component = 0 [kg m^-2 s^-2]
Option = Cartesian Components
END
END
END
END
END
DOMAIN INTERFACE: Domain Interface 1
Boundary List1 = Domain Interface 1 Side 1
Boundary List2 = Domain Interface 1 Side 2
Interface Type = Fluid Fluid
INTERFACE MODELS:
Option = Translational Periodicity
MASS AND MOMENTUM:
MOMENTUM INTERFACE MODEL:
Option = None
END
END
END
MESH CONNECTION:
Option = Automatic
END
END
Termination and Interrupt Condition Summary
CFD Solver: Run duration reached
(Maximum number of outer iterations)
Boundary Flow and Total Source Term Summary
| U-Mom |
Boundary : Periodic -2.7105E-20
Boundary : wall -2.7353E-06
Sub-Domain : Subdomain 1 2.7285E-06
Domain Imbalance : -6.8694E-09
| V-Mom |
Boundary : wall -8.6590E-13
| W-Mom |
Boundary : wall -4.2168E-13
| P-Mass |
| Normalised Imbalance Summary |
| Equation | Maximum Flow | Imbalance (%) |
| U-Mom | 2.7353E-06 | -0.2511 |
| V-Mom | 2.7353E-06 | -0.0000 |
| W-Mom | 2.7353E-06 | -0.0000 |
| P-Mass | 0.0000E+00 | 0.0000 |
Wall Force and Moment Summary
Notes:
1. Pressure integrals exclude the reference pressure. To include
it, set the expert parameter 'include pref in forces = t'.
| Pressure Force On Walls |
X-Comp. Y-Comp. Z-Comp.
Domain Group: Domain 1
wall 1.0438E-20 8.2775E-13 4.1040E-13
Domain Group Totals : 1.0438E-20 8.2775E-13 4.1040E-13
| Viscous Force On Walls |
wall 2.7354E-06 3.8150E-14 1.1282E-14
Domain Group Totals : 2.7354E-06 3.8150E-14 1.1282E-14
| Pressure Moment On Walls |
wall -4.1285E-15 -2.0634E-14 3.6912E-14
Domain Group Totals : -4.1285E-15 -2.0634E-14 3.6912E-14
| Viscous Moment On Walls |
wall -2.5427E-16 2.7354E-08 -2.7354E-08
Domain Group Totals : -2.5427E-16 2.7354E-08 -2.7354E-08
| Locations of Maximum Residuals |
| Equation | Domain Name | Node Number |
| U-Mom | Domain 1 | 19625 |
| V-Mom | Domain 1 | 355 |
| W-Mom | Domain 1 | 20944 |
| P-Mass | Domain 1 | 21262 |
| False Transient Information |
| Equation | Type | Elapsed Pseudo-Time |
| U-Mom | Auto Timescale | 1.30661E+04 |
| V-Mom | Auto Timescale | 1.30661E+04 |
| W-Mom | Auto Timescale | 1.30661E+04 |
| Average Scale Information |
Domain Name : Domain 1
Global Length = 3.4200E-02
Minimum Extent = 2.0000E-02
Maximum Extent = 1.0000E-01
Density = 9.9700E+02
Dynamic Viscosity = 8.8990E-04
Velocity = 1.0871E-03
Advection Time = 3.1459E+01
Reynolds Number = 4.1653E+01
| Variable Range Information |
| Variable Name | min | max |
| Density | 9.97E+02 | 9.97E+02 |
| Dynamic Viscosity | 8.90E-04 | 8.90E-04 |
| Velocity u | 1.94E-05 | 1.81E-03 |
| Velocity v | -1.20E-09 | 1.31E-09 |
| Velocity w | -1.13E-09 | 1.56E-09 |
| Pressure | -1.03E-09 | 2.52E-09 |
Old   May 24, 2017, 02:53
Of course the two sides of the translational periodic interface have the same pressure, that is what a translational periodic interface is. All flow variables are the same on both sides of the interface.
All the pressure variation in your flow will be occurring inside your domain, but the inlet and outlet sides will both have the same pressure because your boundary condition choice forced it to be the same.
Old   May 24, 2017, 03:27
AKS
The how can I determine the pressure drop.
Old   May 24, 2017, 03:31
AKS
To add further, When I solve the same problem using domain interface by setting the mass flow rate, I am able to get a pressure drop of 0.0062 Pa at mass flow rate of 0.0004 kg/s and vice-versa.
However, I want to achieve same thing using sub domain option by specifying the momentum source term.
Everything is fine, except how to determine the pressure drop here.
Old   May 24, 2017, 03:32
The pressure drop will be from the start to the end of your source term region. But you should have a think about whether you are actually modelling what you intend.
The mass flow rate option works because the source term is applied in the interface. So the two sides of the interface see different pressures. But when you use unmodified periodic boundaries the pressure is the same, by definition.
Old   May 24, 2017, 03:43
AKS
So it means it is not possible to determine the pressure drop using unmodified periodic boundaries ?
But, I added a momentum source term to account for pressure drop then why not get the pressure drop.
Old   May 24, 2017, 19:30
Please read my post #7 carefully. It answers all these questions.
cfd_begin likes this.
Old   May 25, 2017, 06:31
AKS
In understand, So, the momentum source term is basically the pressure-gradient for the flow.
Multiply this by distance will yield the pressure-drop.
Ghorrocks--You are the Best !
Old   May 25, 2017, 08:09
Yup, you got it. Only a minor issue is that when you calculate the pressure drop per unit length you will use the length which is not covered by the source term.
Pressure drop in pipe flow with Large Eddy Simulation xerox FLUENT 1 October 16, 2019 09:55
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 06:35
Boundary conditions for known pressure drop t.oliveira OpenFOAM Running, Solving & CFD 4 March 4, 2016 14:46
Pressure drop of valve with valve opening of 30% elogesh Main CFD Forum 2 January 5, 2007 13:30
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
