Eulerian vs Lagrangian
Like Tree2Likes
  • 2 Post By Dan Williams
Old   April 17, 2001, 02:14
Default Eulerian vs Lagrangian
Helal
Can anybody explain the basic differences between the Eulerian and Lagrangian Particle Tracking?
Regards,
Helal
Old   April 17, 2001, 08:12
Default Re: Eulerian vs Lagrangian
Jan Rusås
In the Eulerian approach is both the fluid/gas and the particles treated as continuum and continuum equations are solved for both phases with an appropriate interaction. In the Lagrangian approach, is the fluid/gas still treated as continuum, but the particulate phase is treated as single particles, where particle trajectories, representing a stream of particles, are calculated as a result of forces acting on them.
The Eulerian model is typically used, when there are many particles, high mass loading,.
Hope it helps
Regards Jan
Old   April 17, 2001, 21:53
Helal
Dear Jan,
Many thanks for your excellent explanations.
Could you please explain which approach is suitable for coal combustion modelling?
In CFX4 Lagrangian approach has been used.
Regards,
Helal
Old   April 18, 2001, 01:00
Dan Williams
Seems to me that this would depend on what part of the coal combustion modelling you are interested in simulating.
If you are interested in the region near a nozzle outlet, where the particles might behave as a single fluid, then an eulerian model would probably be fine. In addition to that, the particles must also be of roughly uniform diameter (which is probabably not the case).
However, if you are wanting to simulate regions further from an injection port, where the particles have spread out a fair bit, and will likely have a uneven spread of particle diameters then a lagrangian approach is likely the better candidate.
CFX-4 can do either.
Dan.
kennyboy and Rohit4689 like this.
Conversion of computed velocities in Lagrangian coordinates to Eulerian coordinates SMM STAR-CD 4 June 5, 2011 10:20
lagrangian and eulerian representaions kakollu Main CFD Forum 14 February 12, 2010 12:35
lagrangian vs eulerian approach leopoldo luongo CFX 1 June 19, 2006 11:12
Arbitrary Lagrangian Eulerian Methods Soheyl Main CFD Forum 1 June 12, 2006 04:42
Comparison between Eulerian and Lagrangian Models Ricardo Damian CFX 0 September 3, 2001 20:13
