User routines cannot be used in the large memory partitioner?
Like Tree2Likes
  • 1 Post By ghorrocks
Old   March 13, 2017, 00:19
Default User routines cannot be used in the large memory partitioner?
Tony
doublestrong is on a distinguished road
I would like to setup user routines in CFX. But it is written in CFX Help that user routines cannot be used in the large memory partitioner. So what is the so-called large memory partitioner? Is it the number of partitions while defining Run? What is the maximum partitions if use rountines are used?
Thanks in advance,
Tony
doublestrong is offline   Reply With Quote
Old   March 13, 2017, 05:44
When you do a multiprocessor simulation it has two steps:
1) Partition the mesh into the required number of partitions
2) Solve it by sending each partition to a core.
Step 1 requires the entire mesh to be in memory for it to be partitioned. If your model has billions of nodes that is a challenge. So the large model partitioner is used to help here. See the documentation for further details.
If you have enough memory to partition your model as it is then do not use the large model partitioner. It is only used when you run out of memory.
doublestrong likes this.
Old   March 13, 2017, 06:26
Tony
Thanks, Horrocks.
The mesh nodes number is about 6 million and I got sufficient memory for this job. I go back to read the Help, but I am not sure if my understanding is correct. I have 28 cores on my computer, so I had better to select 28 partitions to make a parallel computation as fast as possible? If I just select one partition, then there would be only one processor joining the job?
As shown in the help documents, if user routines cannot be used in the large memory partitioner, I have to define my run which incorporates user routines with small memory partitioner and the computation speed would be slow. Do I understand it correctly?
Thanks in advance.
Old   March 13, 2017, 06:33
Do not assume that 28 partitions will run fastest. I would test 1, 2, 4, 8, 16, 28 and you will probably find the performance decreases once the partition count gets large. Designing compute clusters which run well with large number of partitions is a challenging area.
If you don't need the large partitioner (and for a 6M node mesh you shouldn't) then just use the default partitioner. You appear to have misunderstood - the large memory partitioner is only to be used when you run out of memory on the default partitioner.
Old   March 13, 2017, 06:36
Tony
Thanks, Horrocks.
cfx, partitioner, user routines
Memory error? Young CFX 3 September 30, 2008 12:33
User fortran routines, DEBUG AND OUTPUT Bloshchitsyn Vladimir CFX 5 October 29, 2007 02:31
particle user routines Felix CFX 1 July 24, 2006 13:32
User routines sac CFX 1 December 8, 2005 11:42
CFX-5.7.1 MPICH distr. parall. + user routines Claudia CFX 2 March 18, 2005 12:39
