Recirculation over wing
Like Tree1Likes
  • 1 Post By ghorrocks
Old   March 10, 2017, 17:02
Default Recirculation over wing
Ferruccio Rossi
frossi is on a distinguished road
I am simulating high subsonic flow (Mach 0.75) over a wing at 2.5 deg angle of attack at ambient conditions found at 10,000 m. When I look at the velocity streamlines in my results, I get what looks like a region of very low velocity, recirculating air over the wing (see pics). How can it be? Especially given the high speed of the wing. Could it be a region of flow separation, and the low velocity is due to the turbulent flow? What's even more confusing is that such phenomenon occurs only in that specific section of the wing.
Can someone explain what could be the cause and if it is a problem for my simulation? Thank you very much.
frossi is offline   Reply With Quote
Old   March 11, 2017, 05:31
How can it be?
Your wing has a separation at that point. You can get separations at high Reynolds numbers and low Reynolds Numbers. If the angle of attack is high enough it will separate.
This comment suggests you need to do some reading into turbulent boundary layers on airfoils. At high Re the flow over just about the entire wing will be turbulent. The recirculation will be a region of very high turbulence intensity.
It looks like it is caused by either a change of camber on the long section of wing, or a effect due to the sharp transition from one wing segment to another nearby. Both of these effects are normal design flaws which can lead to recirculations.
You need to decide whether this effect is real or just a numerical artefact. As I have explained this effect could quite possibly be real. If you have done validation and verification of your simulation you will know whether your simulation is accurate or not. So you can work this out for yourself.
frossi likes this.
Old   March 11, 2017, 16:46
Ferruccio Rossi
thank you, I will look into this.
mach, recirculation, streamlines, velocity, wing
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 13:42
[ANSYS Meshing] Meshing fluid around sharp edges of a 3D insect wing. minglis ANSYS Meshing & Geometry 1 February 2, 2017 10:14
Wing FSI simulation: Shell elements or 3D solid body? frossi CFX 3 June 15, 2016 21:02
Using the wing mesher GavinB STAR-CCM+ 1 November 20, 2015 02:14
[snappyHexMesh] Meshing 3D wing (hydrofoil) fails klausb OpenFOAM Meshing & Mesh Conversion 0 December 28, 2011 15:26
