Creating contours on slice/planes through the geometry |
March 6, 2017, 17:00 |
Ai
Rep Power: 10 |
I am currently doing my disso on fuel injectors and I have done some pseudo transient simulations to aqquire some data. On CFD post I load this data, and I was asked to replicate some planes inside my diesel injector as shown below attached. I have been trying and trying but with no luck I can't seem to replicate it using CFX or tecplot. However, I did manage to create the contour but not like the picture. I would appreciate help from those more experienced with CFD post thanks! K |
March 6, 2017, 18:19 |
Rep Power: 144 |
This is pretty straight forward in CFD-Post.
Define your 7 planes at the different locations. Then colour the planes with whatever the variable is. Then define custom ranges for the variable to match the colour scale on your image. Note that there does not appear to be any contour plots on your image. Just a colour scale of the variable will be enough. |
March 6, 2017, 19:34 |
Ai
Rep Power: 10 |
Thanks for your reply!
The plane that cuts down is in the ZY axis which is vertically down, as you can see the nozzle is rotated 30 degrees, I have tried rotating the plane by 30 degrees using the "apply rotation" under "view" tab. Is there any alternative way to do this, because I feel like it is inaccurate. I will attach a picture below to show you what i mean: Thank you, I really appreciate the help! I rotated it by 30 degrees and realised it moves completely away from the nozzle. do I have to use the translation tool to move it back, this approach im using seems very unnecessary haha Above image is after rotating 30 degrees |
March 6, 2017, 19:51 |
Rep Power: 144 |
When you define the plane, use the "Point and Normal" method.
March 9, 2017, 15:18 |
Ai
Rep Power: 10 |
Thank you so much ghorrocks
I managed to get it working with the "point and normal"! |
[CAD formats] Anyone use Rhino3D for creating their geometry | s195404 | OpenFOAM Meshing & Mesh Conversion | 3 | December 13, 2011 21:45 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 09:17 |
Creating 2D geometry with ICEM | TobiasZ | CFX | 4 | April 13, 2006 05:32 |
creating 3D geometry from a huge list of vertices. | S.S. | FLUENT | 0 | July 28, 2003 21:13 |
Frustrated creating your own geometry? | Brian Coon | Main CFD Forum | 0 | November 23, 1999 07:36 |
