How to define a fluid-fluid domian interface as porous face
Like Tree3Likes
  • 1 Post By evcelica
  • 2 Post By ghorrocks
Old   February 21, 2017, 04:21
Default How to define a fluid-fluid domian interface as porous face
Evan
EvanGu is on a distinguished road
I want to simulate a CRAC system in data center room with CFX, which supply cold air flow from under floor plenum to room through perforate tiles, so perforate tiles is between two fluid domain as a thin interface. but I do not know how to define the tile opening Percentage in a fluid-fluid domian interface. maybe my question is stupid, but I am a fresh user of CFX software, thanks for your help
EvanGu is offline   Reply With Quote
Old   February 27, 2017, 16:29
Erik
evcelica is on a distinguished road
You would define a loss model or pressure drop at the interface. It would not be by "open area" but rather pressure drop as a function of velocity.
EvanGu likes this.
evcelica is offline   Reply With Quote
Old   February 28, 2017, 04:07
Evan
evcelica, thanks for your reply.
I have another question,can I define the flow direction at the interface? for instance, let the flow streamline perpendicular to the interface.
Old   February 28, 2017, 05:24
Then use a directional momentum source. Use the porous model in the flow direction and set the velocities in the cross directions to zero. If you do a search of the forum you will find examples of how to use a momentum source term to set the velocity to a specific value (which in this case would be zero).
EvanGu and Coolish like this.
Old   March 2, 2017, 03:16
Evan
Your adivce is very useful,and really appreciated.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
define porous zone in fluid domain pannsave FLUENT 0 March 24, 2014 08:27
