Message: Fatal Failure
Like Tree3Likes
  • 1 Post By underrelaxed
  • 1 Post By -Maxim-
  • 1 Post By -Maxim-
Old   February 2, 2017, 07:28
Question Message: Fatal Failure
Daniel
zacko is on a distinguished road
Hello there,
I just started learning CFX and for that I'm trying to made a small simulation with an axial turbine model.
I read the WiKi about what I should look at and I used a YouTube Video of an Centrifugal Pump to set up my simulation.
When I run the simulation a Failure was mentioned, which was already in a forum but there was no solution I could deal with.
| FATAL ERROR :
| Initial values are required for all variables in TRANSIENT runs.
| In this simulation, no initial value was set for
| Variable : Velocity
| Domain : Turbine
| The value can be set using the Initialisation Branch in CFX Pre.
| To bypass this message and use default solver initial values,
| set the expert parameter "transient initialisation override = t"
+--------------------------------------------------------------------+I don't know what it actually means. There is a problem with the velocity, but I made all boundaries I know. Static pressure at the inlet and a normal speed at the outlet.
If you need more Information from the output-file say it.
And sorry If there are any big language mistakes, I'm from germany
Maybe someone can help me
Thank you !
zacko is offline   Reply With Quote
Old   February 2, 2017, 08:49
DL
underrelaxed is on a distinguished road
What were the initialization options used in the video tutorial? They appear to be missing. Check your domain setup under the Initialization tab.
Sent from my SM-G920T using CFD Online Forum mobile app
zacko likes this.
underrelaxed is offline   Reply With Quote
Old   February 2, 2017, 09:57
Maxim
-Maxim- is on a distinguished road
you should use a converged steady-state result to start your transient simulation.
Are you sure you need a transient simulation in the first place? Maybe we start with you describing in detail what you would like to simulate and some screenshots of your setup.
zacko likes this.
-Maxim- is offline   Reply With Quote
Old   February 2, 2017, 10:22
Daniel
Yes the Initialization options were not showed in the Video, so I added them like i thought.
Read again the WiKi again and i should definetly use a steady state simulation. In Autodesk CFD, what I used before, the Transient option was always used.
So what I want to simulate is a axial turbine model, based on a "Hubless Rim Thruster" Design. It is a hubless turbine.
At the Inlet should be a pressure of 5bar and the velocity should be near to 3m/s.
I defined a Rotation and a stationary Area. The Rotation Area are the blades and the hub. The stationary Area is like the casing.
Added two pictures of CFX Setup.
Old   February 2, 2017, 10:32
Maxim
I would suggest you go through some of the tutorials in CFX. There it is explained how you setup a case with rotating parts and interfaces between rotating and stationary parts
zacko likes this.
Old   February 2, 2017, 10:34
Daniel
Okay maybe a good idea - any hint which tutorial I should use ?
Message truncated, error stack: MPIDI_CH3U_Receive_data_found nandiganavishal OpenFOAM Running, Solving & CFD 21 November 19, 2021 02:20
ShockTube, error message. foamer OpenFOAM 8 January 30, 2013 05:31
Error "FLUENT has recieved fatal error" yys88 FLUENT 0 January 22, 2013 15:58
Fatal Error Message Eric FLUENT 0 February 20, 2004 12:20
Error Message!! Matthew Roberts FLUENT 0 January 22, 2003 09:34
