Input power calculation for pump in CFD post
Like Tree1Likes
  • 1 Post By turbo
Old   January 25, 2017, 09:38
Default Input power calculation for pump in CFD post
Dhairyasheel deshmukh
Dhairya@CFD is on a distinguished road
hello,
I am simulating fluid flow through centrifugal pump using cfx. after simulation, I am generating pump report using report template. the head value matches exactly with the experimental data but the efficiency is not matching. I think I am not using correct input power value from the expression. can someone help me how to find the exact input power value for a centrifugal pump in CFD-post?
thanks,
regards,
Dhairya@CFD is offline   Reply With Quote
Old   January 29, 2017, 09:10
turbo is on a distinguished road
See below.
See below my old post related with your question : find how many are missing in your CFD to evaluate torque comparable to test values.
Let me clarify "Pump Efficiency in CFD" for you (and also for many people who have misunderstood it).
Below are what you defined,
"head
(massFlowAve(Total Pressure in Stn Frame )@R1 Outlet-massFlowAve(Total Pressure in Stn Frame )@R1 Inlet)/(ave(Density )@R1 Outlet*g)
shaft power
abs(sum(Velocity in Stn Frame u * Force X + Velocity in Stn Frame v * Force Y + Velocity in Stn Frame w * Force Z)@Calc Wall Region) * numComponents"
The bottom part, what you named "shaft power", is however not the real shaft power because your CFD domain excludes the followings :
- Disk friction on the front and back cavities of the impeller
- Leakage flow power loss through the front and rear seals
- Any power loss due to recirculation flows returning back to the impeller
- Bearing windage power losses
Therefore, any well-designed pump impeller will show over 90% efficiency from CFD if all of them are excluded in the analysis, and if the bottom is a pure calculation of (Torque x omega) from CFX-Post. No surprises ! The CFD pump efficiency cannot be compared to test efficiency unless all of external parasitic losses are included in CFD (but so much rare cases).
In other words, what CFX-Post displays "Pump hydraulic efficiency = (rho * g * Q * dH) / (Torque x omega)" is not a true one, only confusing users. Be careful.
Hazem_9 likes this.
turbo is offline   Reply With Quote
Old   February 2, 2017, 11:05
Thanks for the valuable information. The head value is close to the experimental for a wide range but, efficiency is deviating except one point at all other points.
Yes, CFD don't consider the losses you mentioned. but it is giving perfect results for head calculation. if I want to find the input power value close enough to match with experimental can you tell me the procedure to do it in CFD post.
I have followed one method of calculating (torque on blade*no. obf blades*omega). but that value also don't matches.
thank you,
Regards,
Old   April 27, 2017, 09:06
Hazem
Hazem_9 is on a distinguished road
thank you,
Regards,
To do so, it seems that you have to include what you can include in your model. for example you may include the front and back chambers between impeller and volute so that you can include disk friction and leakage from impeller outlet to inlet
Hazem_9 is offline   Reply With Quote
Transfer output data as input for second calculation mannobot Main CFD Forum 3 December 7, 2018 10:37
Cannot achieve negative wall shear stress values in CFD Post (ANSYS) SAtkins CFX 3 August 3, 2016 15:27
[ICEM] how to manage all the icemc cfd input parameter input for workbench ztdep ANSYS Meshing & Geometry 0 March 12, 2016 04:01
Problem regarding producing streamlines from surfaces in Ansys CFD post gauthamnarayan ANSYS 6 June 8, 2015 08:33
Poly lines in CFD Post ashtonJ CFX 0 December 2, 2010 03:46
