How to pass variables from a workbench script into CFX CCL commands ??
Like Tree1Likes
  • 1 Post By rl00100
Old   September 29, 2016, 03:09
Default How to pass variables from a workbench script into CFX CCL commands ??
Rob Lloyd
rl00100 is on a distinguished road
I am trying to run a parametric study, to assess the effects of changing wall displacement on the mass flow rate. I also want to repeat the same tests with different input pressure profiles which are defined as components of a Fourier series.
I though the easiest way for me to do this would be to loop the workbench script and cycle through what directory the Fourier coefficients for the pressure input should be loaded from. However i am fairly new to both python and perl, so i have not been able to figure out how to pass a variable (folder name) from the work bench script or the ccl.
Is there away to do this or any other alternatives that wont involve me manually rewriting the scripts with the correct directories ?
Thanks, Rob
ann24 likes this.
rl00100 is offline   Reply With Quote
cfx, perl, python script, scripts, workbench scripting
Bug in Workbench CFX Pierre1 CFX 6 August 2, 2017 01:18
CFX problems I got in Workbench Anna Tian CFX 13 July 3, 2017 02:49
FLUENT installation on UBUNTU 12.04 (LTS) teymourj FLUENT 2 March 1, 2017 23:24
[ICEM] set workbench parameter in icem cfd script nnvoro ANSYS Meshing & Geometry 2 April 28, 2013 15:23
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 03:13
