Wall Roughness - Rough Wall
Like Tree2Likes
  • 2 Post By ghorrocks
Old   September 11, 2016, 19:34
Default Wall Roughness - Rough Wall
A
Rodrigo_Eng_Mect is on a distinguished road
Hi, I would like yours opinions! I am simulating the ANSYS CFX a rotor and centrifugal pump diffuser, the boundary conditions is an inlet pressure (0 Pa) and mass flow at the outlet, in fact the rotor has a certain roughness !! I enter this roughness parameter in "Wall Roughness"? For example: 0.1 [mm] - Steel! When I use the "Smooth Wall" My Y + Global option is at 123 when inserting roughness condition my Y + is in 1023! What do you think I enter a value in Wall Rougness? Thank you
Rodrigo_Eng_Mect is offline   Reply With Quote
Old   September 11, 2016, 20:00
Please read the CFX documentation, Theory manual: Turbulence and Wall Function Theory/Flow Modelling near the wall/Mathematical Formulation/Treatment of rough walls.
It explains that rough walls lead to a shifting of the turbulent velocity profile near the wall, which leads to a shift in y+ value. So what you are seeing is the expected result.
Raku and unclewallcn like this.
Old   April 10, 2021, 05:02
YangLu
yanglu is on a distinguished road
HI, How do you decide the wall roughness value with 0.1[mm]? Is this value too high? Thanks.
yanglu is offline   Reply With Quote
Old   April 10, 2021, 05:44
0.1[mm] wall roughness is very small if the rotor is a 14m diameter hydro-power station turbine, but very big if the rotor is a 30mm diameter turbocharger. It all depends on how big the device is.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   April 12, 2021, 11:06
Opaque will become famous soon enough
If I recall correctly, the wall roughness physical height importance is relative (as Glenn suggested). What matters is its influence within the boundary layer, and it is usually done by using turbulent scales.
Similarly to y+, there is a roughness+ (k+).
You probably should read about how k+ is computed, and used within turbulence modeling.
Opaque is offline   Reply With Quote
Old   April 13, 2021, 05:32
YangLu
Thanks. I am calculating the oil drag power of the twin-screw compressors. The power seems very low with the smooth wall. So, I want to add the wall roughness of the rotor surface. By the way, when I enable the non-overlap condition to set the wall roughness = 1e-5, it gives me an error as following, do you know how can I solve this error? Thanks.
Domain Name : rotor
Mesh Coordinates
Details of error:-
Error detected by routine PEEKCS
CDANAM = HOW
CRESLT = NONE
Current Directory : /FLOW/BOUNDCON/ZN7/BCP19/NOVARIABLES/RGH
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Stopped in routine MEMERR |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
Old   April 13, 2021, 09:19
What version of the software are you using?
I recall seeing this error some time ago. You should probably contact ANSYS CFX support, and discuss this error with them. They can provide you a workaround
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
wall roughness effect on pressure drop mactech001 CFX 16 February 22, 2013 06:55
How to set up rough wall conditions weigsi STAR-CCM+ 1 February 28, 2011 10:09
wall roughness with SST turbulence model in CFX10 Vincent CFX 7 September 10, 2007 17:49
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
