July 9, 2016, 13:26 |
expression in CFX POST
Rep Power: 10 |
Hello
I want to create expression to find Froude number (v/(gy)^0.5) at a certain location using line, from expression avgvelocity()@line1/(areaInt(water.vf)@line1/area()@line1)*g )^0.5 but it showed error. also I used the same expression for plane, the same problem occur thanks for your help |
July 9, 2016, 21:22 |
Rep Power: 144 |
Showing the error message might help.....
Note there is no function "avgvelocity()@line1". |
July 10, 2016, 03:34 |
#3 | |
Rep Power: 10 |
areaAve(Velocity)@line1/[(areaInt(Water.Volume Fraction)@line1/area()@line1)*g]^0.5 I used velocity same as in the CFX documentation |
July 10, 2016, 10:03 |
Rep Power: 144 |
CEL does not use square brackets. They need to be normal brackets.
You cannot do areaInt() of a line object. Or maybe you can - but the answer is zero as it has no area. Likewise the area() of a line is zero as well. You still have not posted the error message you are getting.... |
July 10, 2016, 12:47 |
#5 | |
Rep Power: 10 |
https://drive.google.com/open?id=0B3...HZWQWZzRkFHNHc https://drive.google.com/open?id=0B3...1daaXlnZEQxRUU thanks |
July 10, 2016, 20:25 |
Rep Power: 144 |
The error message says exactly what the problem is. There is no variable called "Velocity", there is "U Velocity", "V Velocity" and "W Velocity", or the short version u, v, w.
July 11, 2016, 08:53 |
#7 | |
Rep Power: 10 |
areaAve(U Velocity)@Plane 1/((areaInt(Water.Volume Fraction)@Plane 1/area()@Plane 1)*g)^0.5 |
July 11, 2016, 09:48 |
Rep Power: 144 |
Look in the CFX reference guide for the variable names. You need to get the variable names correct or it won't accept them. It is also case sensitive.
July 14, 2016, 08:23 |
#9 | |
Rep Power: 10 |
I used the velocity variable as cited in CFX reference but same error happen, just for test I used pressure (p) it gives a result as in attached pictures. thanks for your suggestion https://drive.google.com/open?id=0B3...WNlcjVVTDA1Mzg https://drive.google.com/open?id=0B3...VpQZUl1c29OZms |
export expression from CFX post | owarlow | CFX | 5 | November 12, 2019 17:43 |
writing execFlowFunctionObjects | immortality | OpenFOAM Post-Processing | 30 | September 15, 2013 07:16 |
Is it possible to obtain compressor map for axial compressor in CFX post ? | Irondome | CFX | 1 | June 16, 2013 07:24 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 19:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 07:25 |
