A question about timescale
Like Tree2Likes
  • 1 Post By Opaque
  • 1 Post By Opaque
Old   June 20, 2016, 12:01
Default A question about timescale
Aja
aja1345 is on a distinguished road
Is it possible to have different numerical results with different timescales?
In fact, if I change timescale, Do results change?
if I change timescale and results change, what is problem?
Can you explain about timescale briefly?
Thanks.
aja1345 is offline   Reply With Quote
Old   June 20, 2016, 13:18
Aja
Should I use different timescales before and after stall in turbine simulation or not?
Old   June 20, 2016, 13:56
Opaque will become famous soon enough
For steady state calculations, a converged solution should be unique for any value of the timescale. Different values of timescale produce the following results sorted as:
- Diverging results, you must reduce your timescale
- Converged results with a lot of struggle, if converged well, your results are just fine, but you can try reducing your timescale a bit for the next simulations.
- Converged results with an optimal/ideal convergence, do nothing
- Converged results after many many iterations, if converged well, your results are just fine, but you can try increasing the timescale a bit for the next simulations.
- Residuals seems stuck, and they seem to not progress at all, try increasing your timescale and see if it falls in one of the cases above.
The above applies to the Physical Timescale, Auto Timescale options only.
Hope the above helps,
aja1345 likes this.
Opaque is offline   Reply With Quote
Old   June 20, 2016, 14:49
Aja
Thanks.
I almost understand your statement. Unfortunately My English language is not very good.
What is your exact meaning of "struggle" and "stuck"?
if I change timescale and results change, What is the reason?
Old   June 20, 2016, 17:30
Originally Posted by aja1345 View Post
Thanks.
Solution does not converge monotonically
In most cases the solution is unique (definitely for linear systems) if the solution is converged, i.e. residual are small enough that the solution remains unchanged even if the residual are reduced further.
However, you must keep in mind that because the flow equations are non-linear, there is the possibility of multiple solutions and the software may have converged towards one of them. In such situations, you may have to dig deeper to understand if the solution makes sense, is it stable ? is it the most probable solution ?
aja1345 likes this.
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 14:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 16:26
Number of Timesteps and Physical Timescale Leuchte CFX 5 October 15, 2010 11:47
physical timescale keeper CFX 1 October 6, 2010 16:02
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 05:37
