how to set Reciprocating and Rotation motion in CFX
Like Tree3Likes
  • 1 Post By ghorrocks
Old   May 21, 2016, 05:54
Default how to set Reciprocating and Rotation motion in CFX
Aja
aja1345 is on a distinguished road
I want to model the following case:
This case have reciprocating and rotation motion. Is it possible that this case models in CFX without writing Code?
I am grateful that guide me.
Thanks.
Best.
Aja
aja1345 is offline   Reply With Quote
Old   May 21, 2016, 07:00
This is quite straight forward. The reciprocating motion is a simple moving mesh application - but you need to be careful about how you apply it to make it work nicely. The rotation is simply a tangential velocity on the wall boundary, assuming the rotation does end up with just a tangential velocity on the wall.
How big is the reciprocation? How big is the domain width?
aja1345 likes this.
Old   May 21, 2016, 07:40
Aja
reciprocation is between top wall and bottom wall....I want to just simulate this 2 Dimensional model currently. Then, I have to simulate its 3
Dimensional model...therefore, first I want to learn how to set this case and I don't know exact dimensions. According to your statement, i have to study moving mesh because i didn't work moving mesh in Fluent and CFX. Can you explain more about your following statement?why are you saying it?
"but you need to be careful about how you apply it to make it work nicely"
If it is possible, please give me useful links and documentations.
Thanks.
Old   May 21, 2016, 07:56
You have to be careful how you apply it as it is easy to squash the mesh too far and you get negative volume elements and poor quality mesh. You sometimes need to be a little cunning to create a motion which maintains good mesh quality.
If the motion is from the top wall to the bottom wall then this will be tricky with moving mesh alone. You are probably going to need remeshing as well.
Examples of all this is available on the ANSYS customer webpage.
aja1345 likes this.
Old   May 21, 2016, 07:57
Aja
Old   May 23, 2016, 01:50
Aja
In this simulation, Should i add a new material(solid) except Fluid(water)?
Thanks.
Old   May 23, 2016, 08:08
You do not model the reciprocating/rotating object as a solid. You model it as a section cut out of the fluid domain.
aja1345 likes this.
Reciprocating motion of a rod in the water tank sachinthakre OpenFOAM Pre-Processing 3 June 23, 2016 05:44
