Wall Shear in Expression as boundary condition
Like Tree4Likes
  • 2 Post By ghorrocks
  • 2 Post By w.andreao
Old   May 10, 2016, 12:07
Default Wall Shear in Expression as boundary condition
Willian Andrećo
w.andreao is on a distinguished road
Hi everyone,
I have an expression that calculates an emission rate that I want to use as boundary condition for an wall as flux in, which is based on the shear stress.
The expressions I`m using is:
friction velocity = (Wall Shear/Density)^0.5 #unit [m s^-1]
kl = 1e-6[m s^-1] + 6.3e-4[s^1.2 m^-1.2] * friction velocity^2.2 #unit[m s^-1]
emission rate = 0.01[kg m^-3] * kl #unit [kg m^-2 s^-1]
But, when I set this last expression in the additional variable flux, an error has occurred:
Non-scalar variable 'Wall Shear' referenced by parameter 'Additional Variable Flux' in object '/FLOW:Flow Analysis 1/DOMAINefault Domain/BOUNDARY:interface/BOUNDARY CONDITIONS/ADDITIONAL VARIABLE:Concentration'.
Non-scalars are only allowed as arguments to integrated quantity functions.
I tried to simulate anyway, but in the calculation of my additional variable the program crashes.
Do you know how can I solve this problem?
I can input the values of shear stress from other simulation using initialize profile data. But I could not find a way to use these values in the expression.
w.andreao is offline   Reply With Quote
Old   May 10, 2016, 22:02
Two comments:
* Does your equation work if you use the Wall Shear X components? Then you will have three equations for each XYZ direction.
* I am not sure how well CFX can handle units with non-integer exponents. Most people do this in CFX by making the variables unitless so then you can use non integer exponents with no issues with units.
Mazze[ITA] and jingxinrushui like this.
Old   May 11, 2016, 20:53
Willian Andrećo
Yes, CFX-Pre works with the wall shear components. I wrote the shear stress as (Wall Shear X^2 + Wall Shear Y^2 + Wall Shear Z^2)^0.5
Thank you!!
boundary condition, expressions, wall shear stress
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 09:16
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 07:49
how to set up a wall boundary condition according to calculated wall shear stress? gameoverli OpenFOAM Pre-Processing 1 May 21, 2009 09:28
