The ANSYS CFX solver exited with return code 1. No results file has been created. |
April 24, 2016, 11:02 |
Vigneshwaran
Hi Everyone,
I am new to Ansys- CFX and am trying to simulate a rectangular porous domain (porous membrane) as described in the image. The dimensions of the rectangular body are 1000 mm (length) x 20 mm (height) x 0.0001 mm (thickness). I am getting the above said error as soon as i start the solution. Please help me with this. |
April 24, 2016, 13:53 |
Rep Power: 16 |
Have a look at the Output file (*.out). It usually contains messages before the crash which might give an indication of what is going wrong.
April 24, 2016, 14:40 |
#3 | |
Vigneshwaran
I will upload that text from *.out file. pls take a look at it. Thank you for the wisdom & time. |
April 25, 2016, 10:12 |
#4 | |
Rokson K Mathew
Rep Power: 10 |
Solver returns with error code-1 if there is an issue with the def file. First- Check the mesh input units (cm,mm,in) Make sure the setup is setup properly. The out file mentions an error on Re No. Do cross check that too. Cheers! |
April 26, 2016, 03:10 |
#5 | |
Maxim
Rep Power: 13 |
This is the important part of your out file:
error cfx5, membrane, porous domain |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 18:34 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 17:08 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 12:44 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
