Modifying a turbulence model?
Like Tree1Likes
  • 1 Post By Opaque
Old   March 30, 2016, 11:56
Default Modifying a turbulence model?
Luke Cleaver
lscleaver is on a distinguished road
Hi
Im trying to use a modified RNG model reccommended by Reboud et al. i don't know how to modify the formulas in CFX. so how would i do this?
Many thanks
Luke
lscleaver is offline   Reply With Quote
Old   March 30, 2016, 16:18
Opaque will become famous soon enough
You are trying to modify the RNG model using information from the k-w model. That is a risky proposition without careful validation.
Or, you mean to modify the k-w model as suggested (assuming the authors did the proper validation)
Opaque is offline   Reply With Quote
Old   March 30, 2016, 16:41
Luke Cleaver
Thanks for replying
Used wrong image as thats for SST
this is what i need to modify RNG with.
Old   March 30, 2016, 16:57
After selecting the RNG model, open the Advanced Controls for the turbulence model setup, and overwrite the Eddy Viscosity value by your own CEL expression.
Hope the above helps,
Terbulent likes this.
Old   March 30, 2016, 18:15
Luke Cleaver
Very much so
thank you
Old   March 31, 2016, 10:51
Luke Cleaver
Does this look right to you?
Old   March 31, 2016, 11:44
Is your model single phase multicomponent material, or multiphase flow ?
For a single phase multicomponent material, the expression seems correct.
For a multiphase flow model, it is not clear what "density" means. If you intend to be the volume fraction weighted density, I would write it explicitly. That is, MyMixtureDensity = WaterVapour.Density * WaterVapour.Volume Fraction + ....
Old   March 31, 2016, 12:10
Luke Cleaver
It is a multiphase flow model and the "density" is the mixture of the 2 fluids.
Are you saying write a expression for that density? as
WaterVapour.Density*WaterVapour.VolumeFraction+Liq uidWater.Density*LiquidWater.Volume Fraction
Old   March 31, 2016, 12:19
Correct.. Just in case the software assumes fluid phase.
Old   March 31, 2016, 12:22
Luke Cleaver
Okay will try that
Smagorinsky Sub-Grid Turbulence Model vs. Deardorff oksero Main CFD Forum 4 July 29, 2015 11:43
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 20:42
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 10:02
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 14:57
