March 29, 2016, 19:46 |
Fatal Error,very very need your help
Bohong.Zhu
Rep Power: 10 |
Very sorry. My English is not very well, I hope everybody could understand what I said.
I have simulated three phases flow, water(continuous phase), oil(continuous phase) and gas(dispersed phase). The reactor is full of 4/3 of water and 4/1 of oil. The gas has been injected in bottom surface by using velocity inlet boundary, and escaped from top surface which be set as degassing condition. So, there are two regions has been created, which has been connected by a interface (GGI). Between water phase and oil phase, the free surface model has been activated. Interphase transfer is set as free surface and drag force coefficient is set at 0.44. Between water/oil phase and gas phase, Interphase transfer is set as particle model, the drag force and non-drag force has been activated. In my model, I have used the homogeneous turbulence model(k-e) and considered the buoyancy model. However, the fatal error always confused me as follows, I really need someone's help, Very thanks! ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine ASS_MSF_BFORCE Last edited by Ineedyourhelp; March 30, 2016 at 14:08. |
March 30, 2016, 03:57 |
Rep Power: 13 |
it seems that the problem is your buoyancy model. I recommend to double check the buoyancy option and gravity values, density references in both regions. |
March 30, 2016, 14:34 |
#3 | |
Bohong.Zhu
Rep Power: 10 |
Very thanks for your reply. Yes, maybe that you said is also a problem. But, there are two continuous phases (oil and water) in my model. The gas bubble which is treated as dispersed phase rise up and cross the two domians. because of homogeneous turbulence model, the fluid buoyancy model is based on density difference, and I don't consider of the buoyancy turbulence. The gravity value is -9.81 and reference density is same as the density of water. As you know, it is better to choose the continuous phase density as the reference density, but there are two continuous phases in my model, how to deal with it? In order to initialize the reactor is full of 4/3 of water and 4/1 of oil at the beginning, I create two domians. But two domian about the basic setting and fluid models are same. So how to solve this? |
March 31, 2016, 03:50 |
Rep Power: 13 |
can you put a figure of the domains with axis here?
In my opinion, reference density can be the averaged density according to the amount of each continuous fluid in the zone, like: (0.75 * density_water + 0.25 * density_oil)_inlet |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 05:18 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
[snappyHexMesh] sHM: FATAL ERROR: More than six unsigned transforms detected | Djub | OpenFOAM Meshing & Mesh Conversion | 0 | July 15, 2014 05:43 |
Foam Fatal IO error when running pimpledymfoam | orkavic | OpenFOAM Running, Solving & CFD | 3 | December 18, 2013 17:05 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 16:16 |
