March 29, 2016, 14:14 |
CFX setup question
Vanessa Wei
Hi, I am doing an impeller rotating in tube, and the result is not as what I expected. My current setup is that I hold the impeller stationary, and rotating the fluid domain. As I increase the RPM and keep the pressure between the inlet and outlet constant, the mass flow rate at the outlet just doesn't change at all. This gives me and impression that the rotation has no influence at all. Can someone please help check my setup, and let me know if I did anything wrong?
Screen Shot 2016-03-29 at 2.09.36 PM.jpg Screen Shot 2016-03-29 at 2.09.19 PM.jpg Screen Shot 2016-03-29 at 2.08.49 PM.jpg Screen Shot 2016-03-29 at 2.08.00 PM.jpg |
March 29, 2016, 20:10 |
Rep Power: 144 |
You do not model the impeller as a solid for most cases. The impeller is a region removed from the mesh - you model the fluid region around the impeller.
Have a look at the meshes used in the CFX tutorial examples for what you need. Also have a look at how they set up this type of simulation. |
ansys, cfd, cfx, turbomachinery |
question about immersed solid in CFX 12.0 | Anny | CFX | 11 | October 4, 2016 04:22 |
Error in CFX (after setup process) | Milvus | CFX | 2 | September 16, 2013 07:50 |
Question about changing the default length unit at CFX | lnk | CFX | 1 | July 26, 2012 16:16 |
Error in CFX (after setup process) | Milvus | CFX | 0 | May 14, 2011 11:51 |
CFX Distributed Parallel Setup | Behzad | CFX | 6 | November 25, 2010 20:54 |
