CFX error: "enforce system memory limit" controls whether this is a fatal error |
March 27, 2016, 05:06 |
Ian
Rep Power: 13 |
hello,everyone,i have a problem in cfx ,this tip means not have enough memory? how to solve it?
thank you | Host Memory Information (Mbytes) | +--------------------------------------------------------------------+ | Host | Npart | System | Allocated | % | +------------------------+-------+-------------+-------------+-------+ | WSA | 16 | 23542.21 | 27439.56 |116.55 | +------------------------+-------+-------------+-------------+-------+ +--------------------------------------------------------------------+ | ERROR #333100220 has occurred in subroutine Out_MemPar. | | Message: | | | | The allocated memory exceeds the system memory on 1 host(s). | | | | The logical expert parameter "enforce system memory limit" | | controls whether this is a fatal error. | | | | The current setting is: fatal | | | | Allocating more than the system memory may result in slow or | | unreliable operation and is not recommended. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ |
March 28, 2016, 09:33 |
Rep Power: 33 |
It means the software requires more memory than currently available on the machine. You have several options:
- Run the same case in parallel on multiple machines, i.e. reduce the requirements per partition and spread the memory requirements among multiple machines - Reduce the memory estimated by the software and see if it can work with less memory. See memory settings under the advanced control when defining the run - Use the expert parameter provided, and see if it can work even there is not enough memory. I doubt it will, but you can give it a try. Hope the above helps, |
August 23, 2016, 05:02 |
how to change the "The current setting is: fatal"
tata
I have similar problem.
In my case, the percent difference between allocated memory and system's memory is no greater than 1 %. From the out file there is this error description message that says "The logical expert parameter "enforce system memory limit" controls whether this is a fatal error. The current setting is: fatal" So i've been thinking about changing the current setting value of the logical expert parameter "enforce system memory limit" to be not "fatal", hoping the solver may be able to solve my case. But i cant find such "enforce system memory limit" in the expert parameter tab. Can anyone share me some enlightments? Thanx in advance. |
August 23, 2016, 05:19 |
Rep Power: 10 |
Decrease your mesh elements or upgrade your computer with more memory.
August 23, 2016, 06:52 |
Rep Power: 144 |
Or use distributed parallel - and if you are already use more nodes.
October 11, 2016, 05:38 |
Jiri
Rep Power: 13 |
October 11, 2016, 06:21 |
Rep Power: 144 |
Because the system does not have enough memory to run the simulation as it is configured, so if you reduce the memory used somehow it might run. Isn't that obvious?
October 12, 2016, 05:45 |
Jiri
Rep Power: 13 |
Memory allocations have never been obvious to me :-)
Thank you |
March 22, 2020, 18:58 |
#9 | |
Yuhan Wang
Rep Power: 6 |
Hi Sir, I met the exact same problem here. I also could not find the "enforce system memory limit" in the expert parameters. I did like you suggested for running in distributed parallel: Intel MPI Distributed Parallel, but a new error was shown like below: +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The Intel MPI hydra service is not running and/or no user | | credentials have been registered. The output given by E:\ANSYS | | 2019R1\ANSYS | | Inc\v193\commonfiles\MPI\Intel\2018.3.210\winx64\b in\mpiexec.exe | | was: | | | | FAIL: Unable to read the credentials from the registry. | | | | Either: | | | | 1. Install Intel MPI using the ANSYS Installer, caching the | | password as per the installation instructions. CFX must then be | | restarted. | | | | 2. Alternatively, configure MPI using the commands: | | | | cfx5parallel -install-impi-service | | | | cfx5parallel -register-impi-user | +--------------------------------------------------------------------+ can you give me some other suggestions? or do I need to choose "IBM MPI Distributed Parallel"? Thank you in advance! |
March 22, 2020, 19:20 |
#10 |
Rep Power: 144 |
You need to configure the Intel MPI service as described in the installation instructions, or change to a different MPI method (eg IBM).
March 22, 2020, 21:17 |
#11 | |
Yuhan Wang
Rep Power: 6 |
I tried with "IBM MPI Distributed Parallel" but it did not work. The original error "The allocated memory exceeds the system memory" back to the solver. I wonder if the Distributed Parallel is the only method to solve that? Is there any other way for that? Or how could we find the "enforce system memory limit" in the expert parameter setting? Thanks in advance! |
March 23, 2020, 05:19 |
#12 |
Rep Power: 144 |
The only way to fix the "exceeds system memory" error is to either put more memory in the machine or to make the simulation size in that node smaller but using more partitions or a coarser mesh.
March 23, 2020, 09:15 |
#13 | |
Yuhan Wang
Rep Power: 6 |
The thing is I met an "insufficient allocated memory" problem before and it took me a whole weekend to fix that, and finally it shown that the problem is due to I set up the wrong rotational axis (not sure how the axis related to the memory stuff). The mesh is only 1.5million and my computer has 8GB ram I think it is fine to run that, so I am wondering if the memory problem this time could also happen for some setting in CFX-Pre rather than the computer itself? Thanks in advance! |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 21:16 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 10:31 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 08:24 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 18:38 |
