March 20, 2016, 06:45 |
free surface
hossein
Rep Power: 14 |
Hi
I am trying to simulating free surface in moving container. Unfortunately i have faced very weird problem, which water's surface is getting like it is evaporating. So i make it more simple to find problem so i canceled the movement of container and it is just a cube contains water. Surprisingly the problem occurs again. [below image] why this occurs? Also when I increase water height it doesn't occur. Please help me ASAP |
March 20, 2016, 19:51 |
#2 | |
Rep Power: 144 |
If the free surface goes bezerk like this it is a sign that the free surface model is not well set up for your simulation. You will need to adjust the defaults to make it more stable. But exactly which setting you need to change is highly problem dependant, so I recommend you try all the settings and see which ones help you. I recall recommending you to do this check before - so it looks like you have not done it yet.
March 23, 2016, 01:07 |
hossein
Rep Power: 14 |
I have tried various setting for free surface. what is strange, is that when i increase water height ,exceeding a exact height, this problem is not happening.!!!
March 23, 2016, 17:37 |
#4 | |
Rep Power: 144 |
If the water height is increasing then you have a conservation problem. This can mean your convergence is too loose. Also this can be helped by switching your volume fraction coupling option. |
March 27, 2016, 11:54 |
Rep Power: 16 |
Hi Hossain, try reducing the time step, I mean reduce it to ridiculously small amount. If you think your time step is already small enough, try using an adaptive time step and monitor your step, you will see how low it goes.
free surface |
how to capture free surface cells? | MichaelVS | FLUENT | 1 | June 10, 2015 03:18 |
Floating dok on waves: free surface divergence | Galchenko | CFX | 3 | September 11, 2014 19:04 |
Multiphase flow. Dispersed and free surface model | Luis | CFX | 8 | May 29, 2007 19:13 |
Equilibrium of a free surface under surface tensio | Ryan | Main CFD Forum | 1 | August 7, 2001 17:14 |
Modeling Free Surface Flows | Elliot Schwartz | Main CFD Forum | 5 | August 25, 1998 22:03 |
