direction of velocity in CFX pre
Like Tree2Likes
  • 1 Post By ghorrocks
Old   March 16, 2016, 15:52
Default direction of velocity in CFX pre
yaseen
yaseen wsu is on a distinguished road
hello every one, I simulate free surface flow using transient simulation, but it need initial conditions like velocity, pressure ....., my direction of inlet flow is opposite to X,Y, so it is required to enter velocity in negative (like gravity) as shown in attached image.
thanks
http://www.cfd-online.com/Forums/att...1&d=1458157947
yaseen wsu is offline   Reply With Quote
Old   March 16, 2016, 22:00
I do not understand your question. But if you cannot define a good initial condition then starting from a zero flow initial condition usually works.
yaseen wsu likes this.
Old   March 17, 2016, 03:14
yaseen
thanks, (actually I know initial condition only I have problem in sign) my question about direction of velocity, for example, when enter gravity acceleration we always put in negative (-9,806) when opposite to the vertical direction. for velocity, is the same thing when velocity opposite to the X or Y direction.
Old   March 17, 2016, 03:16
Yes, if you want a velocity in the opposite direction to the axis definition this means the velocity is negative. This is how all vector quantities work, so it applies to displacements, velocities and accelerations and any other vector variable you need to define.
Old   March 17, 2016, 03:21
yaseen
Thanks a lot
only 1 of many named selections not showing up in cfx pre mihirbhagat CFX 2 April 26, 2019 05:56
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY everest20 FLUENT 1 July 13, 2015 09:35
Is there a way to change settings in CFX pre file or play sessions on it without open Pierre1 CFX 4 March 13, 2015 16:38
Velocity Vectors shown in both direction Blue Fluent Multiphase 0 June 4, 2014 03:34
Results of CFX Simulations Sof_70_Usthb CFX 3 July 9, 2011 07:15
