Coordinate of min/max-value
Like Tree1Likes
  • 1 Post By -Maxim-
Old   February 26, 2016, 06:19
Default Coordinate of min/max-value
Livsviktigt Flöde
livsviktiftflode is on a distinguished road
I am trying to find the coordinates of the minimum value of pressure in one domain and the maximum pressure in another domain. Does anybody have a suggestion on how to do this?
I have tried with:
Point@maxVal(Pressure)@domainX
but I am quite new to this and it doesn't seem to work :-(
livsviktiftflode is offline   Reply With Quote
Old   February 29, 2016, 03:52
Maxim
-Maxim- is on a distinguished road
have you tried the search function of this forum and the suggested methods in those other threads? Here is one example.
edit: create a point of 'variable maximum' and select pressure as variable. File --> export as location your point, select variable and check 'export geometry information'. This will give you a csv-File with the coordinates for that point and the value of the variable.
You might want to create a script for that in case you have to do that more often
aero_head likes this.
-Maxim- is offline   Reply With Quote
All Mach number implicit solver with Kurganov-Tadmore scheme - pisoCentralFoam mkraposhin OpenFOAM Programming & Development 106 February 27, 2024 18:38
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 15:26
How I can introduce my power heat (W) in chtMultiRegionFoam? aminem OpenFOAM Pre-Processing 32 August 29, 2019 03:23
Beginner help, coordinate udf with output file nb92 Fluent UDF and Scheme Programming 0 March 20, 2014 05:16
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
