How to import a Centrifugal-Fan Impeller (.sldprt) into TurboGrid? |
February 25, 2016, 13:27 |
Saeid Ghouli
Rep Power: 11 |
Dear CFD-online users;
I would like to have CFD & Structural analysis on a Centrifugal-Fan Impeller to find out the optimum thickness of the Hub. To do so, somebody tolled me that I should insert my SolidWorks model of Impeller into TurboGrid and then run an steady-state CFD analysis on it (with the use of CFX). After that, I should use the Pressure contour results for running a static Structural analysis and finally find the optimum thickness of Hub. Now, I have 2 main questions here: 1. Is the procedure mentioned above, alright? 2. How to import and make a Passage from my SolidWorks model for using in CFX? (as you know, there is always a sliced passage used for Turbomachinery analysis.) Thank you in advance for your cooperation. Saeid Ghouli Last edited by saeidghouli; February 25, 2016 at 13:29. Reason: Mistake found |
February 26, 2016, 06:48 |
Rep Power: 13 |
the procedure seems reasonable. For importing the geometry into the Turbogrid, you can import curves (coordinates) of the hub, shroud and blade. also if you can model the impeller in BladeGen software, it is easy to import the blade gen file into the turbogrid. As far as I know there is not a direct interface between Solidworks and TurboGrid. |
February 26, 2016, 06:55 |
#3 | |
Saeid Ghouli
Rep Power: 11 |
Thank you for your helping statements.... But one other question: How to obtain those .curve files? Thanks again. |
February 26, 2016, 07:25 |
Rep Power: 13 |
Unfortunately I have not worked with Solidworks, but as other CAD software, it should be a way to export a case as different curve files or coordinates.
Also you can open the exported file from Soliworks with notepad, and export curves manually. |
February 26, 2016, 07:27 |
Saeid Ghouli
Rep Power: 11 |
February 26, 2016, 07:53 |
Saeid Ghouli
Rep Power: 11 |
Excuse me again....
Do you happen to know how to make a blade set (i.e. a Passage) for my analysis? |
February 26, 2016, 08:20 |
#7 | |
Rep Power: 17 |
February 26, 2016, 09:04 |
#8 | |
Saeid Ghouli
Rep Power: 11 |
Do you happen to know how to make a blade set (i.e. a Passage) out of my impeller, for my analysis? |
February 26, 2016, 10:01 |
Is there any ansys document about this thread?
#9 |
Saeid Ghouli
Rep Power: 11 |
Thanks for all the contributions to this thread!
One more request is that doese anybodey happen to have a comprehensive document (preferably an Ansys document) on how to: -make a passage (blade set) from our CAD model -extract .curve files -and how to do the rest of analysis All the helpful answers are highly appreciated. |
February 26, 2016, 10:18 |
#10 |
Rep Power: 17 |
In DM, "ExportPoints" will create .curve file.
October 22, 2016, 22:38 |
#11 |
Have a nice time!
Rep Power: 11 |
I wanna export points of a blade which has a v cut at its edge but when I export points the blade is shown in turbogrid without cut...what should I do?
centrifugal fan impeller, cfx, static structural |
Centrifugal fan impeller CFD simulation in OpenFoam | ZachJa | OpenFOAM | 9 | June 15, 2024 12:03 |
help : import impeller blade coordinates into turbogrid | darKKnight | Main CFD Forum | 1 | February 26, 2016 05:41 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 04:23 |
Modeling of centrifugal fan in CFD | Simon Williams | Main CFD Forum | 3 | February 20, 2009 16:00 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
