CFX vs. FLUENT
Like Tree23Likes
  • 18 Post By turbo
  • 1 Post By ghorrocks
  • 2 Post By Gert-Jan
  • 2 Post By Opaque
Old   February 8, 2016, 13:12
Exclamation CFX vs. FLUENT
turbo is on a distinguished road
This topic never stops showing up in the forum. Let me help you make it clear.
1. By CFD Code
  • FLUENT : UK college > Creare (US) > Fluent (US) > Ansys
  • CFX : UK Nuclear Research > AEA Technology (UK) > ASC (Canada, CFX-TASCflow) > Ansys
  • STAR-CD : UK college > CD-Adapco
  • FineTurbo : Brussel college (Prof. Hirsch) > NUMECA
2. By Solver Type
  • Segregated : Pressure-based Method of FVM : FLUENT, STAR-CD
- Continuity, momentum and energy equations are solved sequentially.
- Pressure is later corrected by Pressure-Velocity Coupling (like SIMPLE, SIMPLEC or PISO)
- Originally for incompressible flow, but extended to compressible flow
  • Coupled : Time Marching of FVM : FLUENT (RAMPANT), FineTurbo
- Conservative vector forms in time and space
- Explicit (FineTurbo, FLUENT RAMPANT) or implicit (FLUENT) solver with multigrid
- Originally for compressible flow, but extended to incompressible using pseudo-compressibility factor
- Better accuracy in highly compressible flows (maybe controversial)
3. CFX is kind of unique
  • CFX is a coupled solver, but needs the pressure-velocity coupling, too. It belongs to the Pressure-based group.
  • CFX is fully implicit, relatively faster than FLUENT, but requiring much storage.
  • CFX is a cell-vertex code, while FLUENT a cell-centered.
  • CFX has a shape function borrowed from FEM to evaluate gradients, but FLUENT uses the staggered grid concept.
4. CFX vs. FLUENT
  • CFX has more friendly GUI for turbomachinery users (that was a kind of business strategy for CFX-TASCflow to survive competing with FLUENT).
  • FLUENT has traditionally more users in more general applications.
  • Both are now good enough !
5. My recommendations
  • If you simulate combustion, multi-phase or chemically-reacting flows, I'd go with FLUENT segregated.
  • If you simulate a single phase turbomachinery flow, two options are recommended : CFX or FineTurbo. In this area, they are totally different animals. Try out both in your model through a comparison with reliable test data before making a decision.
  • NUMECA FineTurbo grid generation package (Autogrid) has been frequently agreed more powerful and of higher quality, but the Post still looks not easy to love.
turbo is offline   Reply With Quote
Old   April 12, 2021, 16:36
Brett
Bdew8556 is on a distinguished road
Thanks for that.
So Fluent uses the FVM and CFX uses the FVM with Finite elements? I've heard it described that way.
I also posted on whether this has anything to do with Fluent being able to handle 3D meshes but CFX not being able to?
Bdew8556 is offline   Reply With Quote
Old   April 12, 2021, 19:19
CFX and Fluent can both handle 3d meshes just fine.
You are probably getting confused with 2d meshes: Fluent has a pure 2D solver, but CFX does not have a 2d solver and you need to make a 1 element thick model and ignore the third dimension. This is messier to set up, much slower to solve and uses more memory. This was done simply because CFX did not want to do the development effort to make and validate a 2d solver, they thought the market was going to full 3d so a 2d solver was not worth the effort in their opinion. I have always disagreed with this logic and think this is one of CFX's greatest weaknesses.
aero_head likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   April 13, 2021, 04:54
Gert-Jan
Gert-Jan will become famous soon enough
Originally Posted by Bdew8556 View Post
Thanks for that.
So Fluent uses the FVM and CFX uses the FVM with Finite elements? I've heard it described that way. I also posted on whether this has anything to do with Fluent being able to handle 3D meshes but CFX not being able to?
No. Both Fluent and CFX use Finite Volume Methods to solve the equations. I.e., they are FVM-packages. However, Fluent takes the meshes as generated and stores the calculated values in the center of the cells. It is therefore called a cell-based solver. CFX does not take the meshes as generated. It creates a background mesh around the nodes (corners of the elements). Calculated values are stored in these nodes. Therefore it is called a node-based-solver.
In fact, if CFX converts a tet mesh in the background, it converts this into a polyhedra mesh. Therefore, a solution with a tet mesh in CFX is somewhat comparable to a solution with a polyhedra mesh in Fluent. Solutions with tet-meshes are uncomparable.
So, what you see is that Fluent can read almost every mesh like hex, tets, pyramids, prisms, polyhedra and Hex meshes with hanging nodes (cutcell-technology).
CFX can only handle hex, tet, pyramids, and prisms. It cannot read polyhedra and hex-meshes with hanging nodes, because CFX cannot convert them in its background process to a polyhedra mesh.
rmerlob and aero_head like this.
Gert-Jan is offline   Reply With Quote
Old   April 13, 2021, 09:08
Opaque will become famous soon enough
Just for clarification, ANSYS CFX never converts the original mesh into a polyhedral mesh explicitly, i.e. it discretizes the equation on each element sector around a node, and creates discrete equations around a node of the original mesh. The equations are very close to those obtained by explicitly computing the dual mesh, i.e. polyhedral mesh, but they are not identical for all situations.
Otherwise, the description is spot on.
Opaque is offline   Reply With Quote
Mesh and Solve Times for CFX, Fluent, CD-adapco Jade M Main CFD Forum 4 August 28, 2012 03:54
Import CFX def into Fluent eric_wang FLUENT 0 April 18, 2011 14:14
OpenFOAM vs. Fluent & CFX marco Main CFD Forum 81 March 31, 2009 15:22
Fluent Vs CFX, density and pressure Omer CFX 9 June 28, 2007 05:13
Jobs in cfd - fluent or cfx? jobman Main CFD Forum 6 July 5, 2006 16:02
