double tube heat exchanger
Like Tree1Likes
  • 1 Post By ghorrocks
Old   December 7, 2015, 08:15
Wink double tube heat exchanger
mehran
mehyan is on a distinguished road
hi everybody,
I have been trying to simulate a double pipe heat exchanger using ansys CFX15. inner tube is used for hot water flow and outer is used for cold water flow.
in defining boundary conditions both hot and cold inlet is defined in terms of mass flow rate (both have the sane mass flow rate). and then interfaces is determined.
both inner and outer tubes have same hydraulic diameter.
when the calculation is finished the following results was obtained:
temp-cold- outlet= the correct result
temp-hot -outlet= the correct result
inner tube heat transfer coefficient =the correct result
inner tube Re number = the correct result
outer tube Re number = the incorrect result
outer tube heat transfer coefficient= the incorrect result
i think outer tube incorrect Re number causes incorrect result in outer tube heat transfer coefficient ,
but the question is that why the outer and inner tube Re number should not be the same whereas the hydraulic diameter, mass flow rate and fluid type in both domain is the same and also temperature changes are not considerable ?
(i have the same problem on fluent)
Kindly help me.
Thanx
mehyan is offline   Reply With Quote
Old   December 7, 2015, 22:16
How are you modelling this? How are you calculating Re? The Re number is not used to calculate anything so how can that affect the result?
mehyan likes this.
Old   December 8, 2015, 09:03
mehran
Thank u for ur kind repy. i myself consider Re effect on the surface heat transfer coeff, but i dont know is it true or not .
i calculate Re number via velocity that cfx give us after calculation end.
(cfx give me different velocity in each domain, while hydraulic diameter and mass flow rate are same .)
so my main question is that Re in both inner tube and outer tube should be the same in equal hydraulic diameter and mass flow rate (whit a bit changes in temp that cant effects) ?
Subsequently, whit different Re should i have different heat transfer coeff and also different friction factor?
Old   December 8, 2015, 14:12
mehran
and is there any expression to show nusselt number in a double pipe heat exchanger in cfx?
Old   December 8, 2015, 17:44
What velocity are you using? Please show where this is coming from.
Nusselt number - this is covered in any heat transfer textbook. If you have problems transferring it to CFX post a new question on it.
double pipe
New densitybased solver AeroFoam giulio_romanelli OpenFOAM Running, Solving & CFD 48 January 15, 2016 09:20
shell and tube heat exchanger... ganesh chakravarthi CFX 3 July 6, 2015 19:44
[GAMBIT] Modelling of Helical-rod inserted in the inner tube heat exchanger is required fahad02999 ANSYS Meshing & Geometry 9 August 11, 2010 09:14
Modelling of Helical-rod inserted in the inner tube heat exchanger is required fahad02999 Main CFD Forum 0 February 22, 2010 19:54
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
