Having trouble with understanding of what is y+
Like Tree1Likes
  • 1 Post By Antanas
Old   November 12, 2015, 11:43
Default Having trouble with understanding of what is y+
Anton
AntonZ is on a distinguished road
I have read lots of things about y+, including ANSYS help, this forum and other CFD-dedicated sites.
But I still have a mess up in my head regarding that value.
"Officially" y+ is a non-dimensional (regarding velocity and viscosity) distance to the wall.
y+ tells me, in which region of the near wall layer I put my first node, if I choose a certain cell size.
So why in Ansys Turbogrid do I set y+ value?
I should calculate an y+ value and then choose a cell size, depending on what I want to model, isn't it?
Or the question here
"Today we will consider three critical questions that are often asked by CFD engineers when developing or refining a CFD simulation:
Do I have an appropriate Y+ value and a sufficient number of inflation layers?"
must be reformulated to "Do I have an appropriate 1st cell size with respect to my y+ value?"
Because for the flow with fixed viscosity, Reynolds, velocity, etc.
y+ is also fixed. Is that right?
It looks like some people define y+ as a dimensionless distance, while others (incl. ansys) treat y+ as a 1st cell size.
AntonZ is offline   Reply With Quote
Old   November 12, 2015, 15:00
Antanas is on a distinguished road
Originally Posted by AntonZ View Post
Your choice of y+ value usually depends on turbulence model choosen. Turbulence models have recommended y+ ranges. Next, y+ is related to y (dimensional distance of first mesh node from wall) and flow properties (I think you can easily find formulas). So after you choosed y+ and determined characteristic flow properties you can evaluate y to create your mesh properly.
ssmacae likes this.
Antanas is offline   Reply With Quote
Old   November 13, 2015, 02:49
Anton
OK, lets be more specific.
I have a centrifugal compressor, RANS + SST.
The initial meshing was done with y+ 200 (Re 1.4e+06).
In real calculation in post processing CFX Post shows me y+ = 830.
Which mesh size should I set next (in a refined grid), if I don't need viscous sublayer.
Should I refine my mesh at all?
Old   November 13, 2015, 06:11
You need to do a mesh refinement study and find out. All simulations are different. Some will require a finer mesh, and some will be just fine with large y+ like that.
Old   November 13, 2015, 14:35
I think that if you don't need viscous sublayer your y+ shouldn't be less than 11. Better >30.
cfx, turbogrid, wall model, yplus
Trouble with compiling UDFs in FLUENT cp703 Fluent UDF and Scheme Programming 28 June 1, 2018 04:22
MUSCL scheme: having trouble understanding what total variation diminishing means JMDag2004 OpenFOAM Running, Solving & CFD 2 January 16, 2015 09:10
Trouble understanding differences between body-fitted and boundary-fitted coordinates hfsf Main CFD Forum 1 September 18, 2013 05:44
Understanding pimpleFoam convergence criterion Nucleophobe OpenFOAM Running, Solving & CFD 0 March 13, 2013 19:46
[snappyHexMesh] basic understanding of sHM colinB OpenFOAM Meshing & Mesh Conversion 1 October 6, 2010 09:17
