October 18, 2015, 10:38 |
control convergence criteria?
Hydreaulic structures
Rep Power: 15 |
hi dear all
i doing run and finished, unfortunately i dont control convergence criteria (residuals and imbalane) in during solver manager with monitor plot, now how i can control this criteria in cfx-post? i want control that finished solver be induce of reach to max iterations or convergence criteria Is satisfied? thanks a lot for any comment. best regards |
October 18, 2015, 20:41 |
Rep Power: 144 |
Convergence criteria affect the simulation. It does not do anything in post processing.
October 19, 2015, 06:00 |
#3 | |
Rep Power: 18 |
Or you can simply look inside .out file to see the reason solver finished the run. |
October 19, 2015, 12:13 |
Rep Power: 15 |
der antanas
unfortunately i dont underastand your mean, how i can open solver manager in stand alone mode? about second method as shown figure , i have about 43.out file in my reult file induced stops in during run, how open out file and what reason exist for solver finished run with look inside out file? if your possible, please explain more. |
October 19, 2015, 20:09 |
Rep Power: 144 |
Open the .out files in any text editor.
October 20, 2015, 00:47 |
Rep Power: 18 |
Via CFX Launcher
Each .out file is text file which corresponds to separate solver run. If you want to know why did 43rd solver run stop, you should open 43rd .out file. Inside that file look for 'Termination and Interrupt Condition Summary' section near its end. |
October 20, 2015, 13:52 |
Rep Power: 15 |
hi dear anatans
first of all , thanks for clear explanation unfortunately still, i have two question, i went cfx laucher, cfx solver manager, view run information and loaded my .res file and then view RESIDUAL as shown follow. Do you mean that was?(select your .res file to see corresponding Solver output, Residuals plots etc.) max res residual located top 1e-04 that define for residual target, but RMS resdidual target located under it, i define residual type RMS in cx pre, Is it is no problem? as you mentined i open out file in note pad , but i dont see any text about terminate, i attached ,out file, if your possible please check it. thanks for attention |
October 20, 2015, 14:06 |
Rep Power: 15 |
October 20, 2015, 22:54 |
#9 | |
Rep Power: 144 |
October 21, 2015, 06:10 |
#10 | |
Rep Power: 18 |
Your file seems truncated. When you open .res file in CFX Solver manager it should also load corresponding solver output file (look at 'Out File' tab), you can investigate it there. |
October 21, 2015, 06:54 |
#11 |
Rep Power: 15 |
hi dear antanas
thanks a lot again for quick and clear answer dear antanas, i find condition summary in outfile tab, i attached in here. whether it means that before solver raeched maximum number of iteration or residual target, solver finished induced of recah to total time that i defined? dear antanas , in transient simulation usually what number of iteration recommended? I considering total time 52s with time steps 0.08, my run was very long, about 4 day, also my results is good. Please guide me Best wishes |
October 21, 2015, 09:59 |
#12 | |
Rep Power: 18 |
October 21, 2015, 10:18 |
#13 |
Rep Power: 15 |
dear antanas , sorry , my mean was same cofficient loops that I say it wrong number of iteration.
Is there such a situation ( However solver is finished induced of reached to simulation time but my result is good in comapred to experimental results) ,simulation cant be correct not at all? only have one problem was falling water surface in inlet, i expressed this problem in this forum, according to glenn , it was inducing of location define inlet in my model. i appreciate you for all hamid Last edited by hamidciv; October 21, 2015 at 12:51. |
October 21, 2015, 13:54 |
#14 | |
Rep Power: 18 |
October 21, 2015, 14:25 |
#15 |
Rep Power: 15 |
dear antanas , sorry for My bad writing
Despite this situation, in my simulation, whether it is wrong? (my mean this is :there is no chance of being correct results in my model And it is certainly wrong?) If the answer is yes, why my results is good? i defined coefficient loops in model 1 to 10 or same default in cfx, with regard my simulation time is high (52s), whether lack of converging in my model can be induced of high coefficient loop? |
October 21, 2015, 15:38 |
#16 | |
Rep Power: 18 |
Why do you think that you have lack of convergence? Because of RMS target = 1e-4? Again it's up to you to decide what accuracy is needed. Maybe in your case the values that you use are sufficient, considering good agreement with experiment. |
October 21, 2015, 16:25 |
#17 |
Rep Power: 15 |
What makes I think me, my simulation is wrong,The reason is that:
as you know , in my model, solver finished induced of reached to simulation time. dear anatans , my main question is: whether finishing of solver induced of reached to simulation time in transient simulation is not problem and it not affect on results? as i know solver should finished Due to the following reasons: 1-reached to convergence criteria 2- raeched to max of iteration that in transient simulation as you epressed it is coefficient loops but in my case , None of the above reasons is not satisfied. i worry about it, Otherwise my result have good agreement with experimental model. many thanks for your follow-up and spending time for me. Last edited by hamidciv; October 21, 2015 at 17:29. |
October 21, 2015, 23:21 |
#18 | |
Rep Power: 18 |
October 22, 2015, 03:18 |
#19 |
Rep Power: 15 |
dear antanas
thanks a lot for all. best regards |
convergence criteria | amol palekar | Main CFD Forum | 5 | August 12, 2010 06:16 |
Convergence criteria | lost.identity | Main CFD Forum | 3 | August 2, 2010 12:23 |
What value shall I set for the Convergence criteria? | steventay | CFX | 7 | May 14, 2010 13:44 |
Convergence criteria | PrandtlGlawert | Main CFD Forum | 1 | August 13, 2009 18:13 |
Convergence criteria | Gaurav | Siemens | 0 | February 3, 2006 05:53 |
