October 6, 2015, 12:36 |
Errors in CFX-Pre after mesh refinement
Tom
Rep Power: 11 |
Hello dear users,
I am currently trying to set up a simulation in CFX 15. The y+ spacing calculator told me that I need a spacing of 6E-6 meters to get the y+ value 1. So I edited the mesh in ICEM and reloaded it in CFX-Pre. But there is a problem because an additional domain called "Primitive 2D" appeared which I did not create. It causes problems because the black arrows that indicate inlet and outlet are now in absolutely weird positions like at the outer walls. So I guess that my simulation will give me wrong solutions. How do I get rid of these strange things just because my mesh is too fine? Thank you |
October 6, 2015, 18:53 |
Rep Power: 144 |
You need to look at the mesh in ICEM and check the boundary patches are correctly defined and the mesh is joined together correctly.
October 6, 2015, 23:36 |
#3 | |
Attique Javaid
Rep Power: 11 |
why does it happen in ICEM? what's remedy? please AJ |
October 8, 2015, 08:37 |
#4 | |
Tom
Rep Power: 11 |
With bigger cells the problems disappear but I think I need the small sizes of cells to get correct results. edit: This is how the mesh looks like with the problematic "primitive 2d"-domains. http://i.imgur.com/hdrhwyy.png Last edited by snejball91; October 8, 2015 at 11:06. |
October 8, 2015, 16:35 |
Edmund Singer P.E.
Rep Power: 21 |
Did you run Check Mesh in ICEM? I bet you might have a volume orientation issue or such.
October 9, 2015, 13:13 |
#6 | |
Tom
Rep Power: 11 |
My fault: I checked the mesh quality at the beginning of creating the mesh with big cells and it was good. I thought it will stay in that quality no matter how fine I make the mesh. But to be honest, I don't know how I could solve that whole problem. The geometry is quite simple and I have no idea how to get better mesh quality with such small mesh sizes. |
October 12, 2015, 09:55 |
Edmund Singer P.E.
Rep Power: 21 |
I take it that this is a hex mesh? You increased the divisions such that you have a very small first layer height?
I recall running into this a while back (years ago). I did solve the issue, but dont recall what I did. If I run into it, I will post the solution. |
October 12, 2015, 10:05 |
#8 | |
Tom
Rep Power: 11 |
Thank you so far. |
October 14, 2015, 07:21 |
#9 |
Tom
Rep Power: 11 |
I found a reason for my bad quality in determinant 3x3x3 and angles.
On the first boundary layer cell ICEM creates triangular cells instead of foursquare cells. http://i.imgur.com/h8JGn2V.jpg |
cfx 15, mesh, primitive 2d, problem |
[snappyHexMesh] snappyHexMesh & Mesh around a missile | sasanghomi | OpenFOAM Meshing & Mesh Conversion | 2 | October 15, 2014 19:54 |
killed "snappyHexMesh" | parkh32 | OpenFOAM Pre-Processing | 2 | April 8, 2012 17:12 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Auto Mesh refinement in CFX | Kushagra | CFX | 4 | June 1, 2008 21:00 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
