How to create interface between periodic model and full model? |
September 13, 2015, 14:16 |
sluzzer
Rep Power: 12 |
I have two domains..
One is axisymmetric and so I made only 30 deg of it Another is not axisymmetric and so I made full model.. Now what is the method to connect these 2? |
September 13, 2015, 20:20 |
Rep Power: 144 |
Use a GGI. If you want the 30 slice to connect to the full thing as if it were the full 360 degrees then use a pitch ratio with a rotating frames of reference. If your domain does not rotate then fool it by setting the rotational speed to almost zero.
October 5, 2015, 12:36 |
sluzzer
Rep Power: 12 |
Ya my domains doesn't rotate and your idea of fooling it with near zero speed is good thanks ghorrocks and sorry for the late reply
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
