July 24, 2015, 06:27 |
Transient Monitor Points
Ano Nymous
Rep Power: 15 |
Hi!
I am running an optimzation and export a User Point for my objective function via the cfx5mondata-command. When I only need the monitor-point-value for the last time step this is pretty straight forward and works fine. I, however, want to do a transient simulation and export the minimum value of my monitor point within a certain timestep range. My idea was to use the Monitor Statistics of CFX 16.0 but the cfx5mondata-command doesn't find "USER POINT,<myvariable> (Minimum)". ("USER POINT,<myvariable>" worked) Can I export a derived variable with cfx5mondata and if so, where can I find the correct name of this variable? Thanks in advance! |
July 24, 2015, 07:02 |
Rep Power: 144 |
I would export the full monitor point history and do it externally to CFX in python or matlab or something.
July 30, 2015, 09:05 |
Ano Nymous
Rep Power: 15 |
Thanks a lot for your reply!
In the meanwhile I used the showvars-command and found that correct name for the monitor is "USER POINT,<myvariable>,,,Minimum". I'm sure your proposal would have worked as well but I'm glad I got away the easy way. |
February 18, 2016, 08:52 |
#4 | |
Maxim
Rep Power: 13 |
I am running into the same problem. I would like to export my user points including the "derived variables" (minimum, maximum and average) of my monitor points. The -showvars command doesn't show those derived variables, though (For steady state calculations I just export the last iteration with the -lastvaluesonly which works great.) Could you please post your full syntax of that minimum/maximum command? Are there 3 commas before Minimum? Thank you for your help |
February 24, 2016, 05:11 |
Maxim
Rep Power: 13 |
I think I got it. I already have to define the statistics in CFX-Pre. This only works with expressions, though, and not with 'Cartesian Coordinates'. And of course that is what I was trying to do. I would like to monitor the absolute pressure at certain fixed points. CFX-Post has 'probes' for that.
I hope I can find a similar function in Pre... edit2: my workaround so far: 1. create source point with specified Cartesian coordinates 2. create expression: probe(Absolute Pressure)@sourcepoint 3. create monitor point with expression 4. check monitor statistics, include Arithmetic Average, Maximum and Minimum and select Timestep Interval I'll check if that works over night. I will edit this post in case it didn't work Last edited by -Maxim-; February 24, 2016 at 10:04. Reason: workaround |
Transient simulations: how to tell its converged (I've read the FAQ & user guides!) | JuPa | CFX | 12 | March 27, 2020 18:24 |
Large transient ".trn" files when doing time average | dtmith | CFX | 2 | June 28, 2015 10:06 |
Transient Statistics Results in CFD Post | ashtonJ | CFX | 2 | October 27, 2014 07:48 |
Transient or Transient Blade Row? | liucheng8602 | CFX | 2 | June 19, 2014 08:03 |
Best practice for transient simulations? | siw | CFX | 5 | October 30, 2010 06:45 |
